LS-prepost中梁单元的方向节点未定义? 80
浏览:1960
错误如下:
*** Error 20225 (STR+225)
     orientation node for beam element # 334239 is undefined
 *** Error 20211 (STR+211)
     reading element card for beam element
     undefined node #           0
     334239         6    357873    357874         0         0         0
     input phase will continue if possible
