ansys fluent遇到问题求解? 10
浏览:1939
Checking case topology...
-This case has both inlets & outlets
-Pressure information is not available at the boundaries.
Case will be initialized with constant pressure
我的出口边界条件均为压力出口,不知道为啥每次初始化之前都会弹出这条信息,求大神解答
