ABAQUS关联VS、IVF出错? 40
浏览:1770
std_user文件中的错误信息如下:
Abaqus/Standard checked out 5 tokens from Flexnet server admin-PC.
<1019 out of 1024 licenses remain available>.
Begin Compiling Abaqus/Standard User Subroutines
10/18/2022 3:56:03 PM
Intel(R) Visual Fortran Intel(R) 64 Compiler XE for applications running on Intel(R) 64, Version 14.0.1.139 Build 20131008
Copyright (C) 1985-2013 Intel Corporation.  All rights reserved.
End Compiling Abaqus/Standard User Subroutines
Begin Linking Abaqus/Standard User Subroutines
LINK : fatal error LNK1181: 无法打开输入文件“use32.lib”
Abaqus Error: Problem during linking - Abaqus/Standard User Subroutines.
  This error may be due to a mismatch in the Abaqus user subroutine arguments.
  These arguments sometimes change from release to release, so user subroutines
  used with a previous release of Abaqus may need to be adjusted.
Abaqus/Analysis exited with errors
如何解决以上错误
