abaqus中报错发现大于机器最大浮点值的数值是什么原因?
浏览:2174 回答:2
报错原文是:
A value greater than the machine largest floating-point value has been found. Check the input file for values greater than 3.40282E+38
Abaqus/Explicit Packager exited with an error - Please see the status file for possible error messages if the file exists.
翻译:
发现一个大于机器最大浮点值的数值。检查输入文件中是否有大于3.40282E+38的值
Abaqus/Explicit Packager退出时出现错误 - 如果文件存在,请查看状态文件以了解可能的错误信息
