ABAQUS基于czm模型的混凝土细观断裂模拟,遇到这个报错是怎么回事?
浏览:1762
*CONTACT cannot be defined on 2D element facets. If the model contains 2D or axisymmetric elements then *CONTACT INCLUSIONS,ALL EXTERIOR cannot be specified, and the first surface name on each data line under *CONTACT INCLUSIONS or *CONTACT EXCLUSIONS must not be blank
