AMESim仿真报错lc_checkout failed with -5 - retrying ? 10
浏览:1992
() lc_checkout failed with -5 - retrying after a short sleep try no:0
() lc_checkout failed with -5 - retrying after a short sleep try no:1
() lc_checkout failed with -5 - retrying after a short sleep try no:2
() lc_checkout failed with -5 - retrying after a short sleep try no:3
() lc_checkout failed with -5 - retrying after a short sleep try no:4
() lc_checkout failed with -5 - retrying after a short sleep try no:5
() lc_checkout failed with -5 - retrying after a short sleep try no:6
() lc_checkout failed with -5 - retrying after a short sleep try no:7
() lc_checkout failed with -5 - retrying after a short sleep try no:8
() lc_checkout failed with -5 - retrying after a short sleep try no:9
() lc_checkout failed with -5 - retrying after a short sleep try no:10
() Checkout failed: No such feature exists.
Feature: hydraulic
License path: D:\AMESIM\V800/licensing/license.dat
FLEXnet Licensing error:-5,357
For further information, refer to the FLEXnet Licensing End User Guide,
available at "www.macrovision.com".
AMESim model D:/AMESIM/w1_ did an abnormal exit!
