Logo 折叠
全网首发仿真工程师项目实训
下载app
返回旧版
首页 成长助手 小邻学院 社区 发现
职业认证 企业服务 行业会议
登录解锁更多功能
还没有账号?立即注册
技术邻
技术引领职场价值
电话
0571-86682823
商务合作
service@jishulink.com
  • 全部  > 
  • CAE仿真
lsdyna流固耦合分析 磨料射流? 100
浏览: 2661 回答: 1
谁会用fem sph dem 耦合做磨料射流分析,fem为实体部件,sph模拟水,dem为磨料,会的联系我,有偿
SPH FEM
全部回答 (1)
结构力学 2023年4月18日
Prepare CAD models: Prepare CAD models for solid parts, water and abrasive particles. The CAD models should accurately represent the geometry and surface roughness of the solid parts and abrasive particles. Mesh generation: Generate meshes for solid parts, water and abrasive particles using appropriate meshing software. Use a fine mesh for solid parts and abrasive particles to capture the small-scale features and surface roughness. Use a coarser mesh for water to reduce computational time. Define materials: Define material properties for solid parts and abrasive particles. Use appropriate constitutive models for each material to accurately simulate their mechanical behavior. For water, define its density and viscosity. Define boundary conditions: Define boundary conditions for solid parts and water. Specify the initial conditions for fluid and solid particles. Define contact and interaction: Define contact and interaction between solid parts, water, and abrasive particles. Use the appropriate contact algorithm to accurately simulate contact and interaction between these entities. Define loads: Define the loads acting on the system, such as external forces or pressure loads. Define analysis parameters: Define the analysis parameters, such as time step, element type, and integration method. Run the analysis: Run the FEM-SPH-DEM coupling analysis in LS-DYNA. Monitor the convergence of the solution and adjust the analysis parameters as necessary to obtain accurate results. Post-processing: Analyze the simulation results to understand the system behavior and make design decisions. It is important to note that FEM-SPH-DEM coupling analysis is computationally intensive and requires significant computational resources. Therefore, you may need to use high-performance computing resources to run the analysis in a reasonable amount of time.
2023年4月18日
相似问题
查看全部
  • lsprepost,lsdyna,ansys/lsdyna? 5个回答
    在lsprepost里面,梁单元方向节点一直显示未定义,但是在keyword检查的时候,却没有发现这个问题。这种应该怎么解决呀
  • lsdyna里的LSDYNA pre没有SPH? 3个回答
    在LS-DYNA中的LSDYNA Pre里添加一个截面,截面详细信息里的单元方式为什么只有ALE(图一),但是别人的里面有好几种方法(图二)有SPH,FEM。是版本的问题嘛?
  • ansys lsdyna求解时为什么时间不长在不同的变化?为什么同一个k文件用lsdyna求解两次,预计用的时间不一样,一个预计9个小时,一个预计50个小时? 4个回答
推荐阅读
ABAQUS中级教程合集--搞定滞回曲线
1点 1点
¥299
汽车仪表模具模流分析的实战讲解
汽车仪表模具模流分析的实战讲解
北卡 北卡
免费
solidworks 2016基础操作入门到精通
新征程学院 新征程学院
免费
ABAQUS钢管混凝土柱温度场及耐火性能分析(未完)
地下结构设计
¥40
前沿技术!大数据分析及人工智能在优化软件中的应用
IDAJ中国 IDAJ中国
¥9.99
新一代智能头灯的动态设计评估与仿真
新一代智能头灯的动态设计评估与仿真
Ansys中国 Ansys中国
免费
UG有限元基础教程
UG有限元基础教程
moonshine🤓 moonshine🤓
免费
0#块箱梁托架法施工结构模拟
0#块箱梁托架法施工结构模拟
yudachuan1105 yudachuan1105
¥200
一线科技工作者接受仿真咨询服务的全过程经验分享
技术邻直播 技术邻直播
免费
UG培训第九课:自由曲面构造法
UG培训第九课:自由曲面构造法
luffy8610 luffy8610
¥20
abaqus座椅滚轮拉脱力强度分析
abaqus座椅滚轮拉脱力强度分析
任总 任总
¥90
汽车模具工艺CAE分析
汽车模具工艺CAE分析
汽车-Albina 汽车-Albina
免费
十分钟快速进行电子产品结构设计方案评估
十分钟快速进行电子产品结构设计方案评估
技术邻直播 技术邻直播
免费
SolidWorks快速入门(操作+技巧+案例)试听课
宸格教育 宸格教育
免费
* starccm+制动盘旋转-冷却仿真(主体更新完成)
qqsww qqsww
¥199
Abaqus在高科技与电子行业的应用(达索直播课程)
水木人CAE-林丽 水木人CAE-林丽
¥10
AQWA软件企业培训(3)  通过ANSYS-APDL建立半潜平台混合模型及混合模型的拖曳力线性化
Nutshell Nutshell
¥30
场景仿真加速智能网联开发测试进程
场景仿真加速智能网联开发测试进程
海克斯康设计与仿真 海克斯康设计与仿真
免费
更智能的3D打印设计和工艺仿真应用网络研讨会
海克斯康设计与仿真 海克斯康设计与仿真
免费
ABAQUS复模态分析
ABAQUS复模态分析
tangxiaocao
¥50
