abaqus提问:THE POWER IS NOT SPECIFIED OR THE SPECIFIED VALUE IS EQUAL TO OR SMALLER THAN ZERO? 100
浏览:2149 回答:1
THE POWER IS NOT SPECIFIED OR THE SPECIFIED VALUE IS EQUAL TO OR SMALLER THAN ZERO. THIS IS NOT ALLOWED IN ABAQUS. Job Job-1: Analysis Input File Processor aborted due to errors. Error in job Job-1: Analysis Input File Processor exited with an error. Job Job-1 aborted due to errors.
Epic
在材料参数中定义power值,一般大于0
2023年1月6日
