Logo 折叠
全网首发仿真工程师项目实训
下载app
返回旧版
首页 成长助手 小邻学院 社区 发现
职业认证 企业服务 行业会议
登录解锁更多功能
还没有账号?立即注册
技术邻
技术引领职场价值
电话
0571-86682823
商务合作
service@jishulink.com
  • 全部  > 
  • CAE仿真
STAR-CCM+多体耦合问题?
浏览: 3351 回答: 2
本人在做一个运动部件耦合另一个运动部件的计算,DFBI主物体在波浪中运动,另外一个物体与之连接,可以旋转,还有一个物体和朱物体刚性连接,在starccm中怎么样考虑设置
STAR-CCM+ 多体耦合
全部回答 (2)
渔人不愚 2024年9月26日
好像建立多个体然后选择多体运动,在体耦合那里耦合上建立的体,这就OK了
2024年9月26日
结构力学 2023年4月18日
To calculate a moving part coupled to another moving part in STAR-CCM+, you can follow these steps: Set up the mesh: You need to create a mesh for your geometry, including the moving parts and their connections. You can use the Mesh module in STAR-CCM+ to create a high-quality mesh that accurately represents the geometry of the parts. Define the materials: You need to define the material properties for each of the objects in your simulation. You can do this using the Materials module in STAR-CCM+. Make sure to select the appropriate material properties based on the physical properties of the objects. Define the physics: You need to define the physics for your simulation, including the fluid dynamics, the motion of the parts, and the coupling between the parts. You can do this using the Physics Continua module in STAR-CCM+. For example, you can define the fluid dynamics using the Navier-Stokes equations, and the motion of the parts using the rigid body motion model. Set up the boundary conditions: You need to set up the boundary conditions for your simulation, including the inflow and outflow conditions, as well as any other conditions that affect the motion of the parts. You can do this using the Boundary Conditions module in STAR-CCM+. Define the coupling between the parts: You need to define the coupling between the moving parts in your simulation. This can be done using the STAR-Coupling module in STAR-CCM+. For example, you can use a Direct Coupling method to transfer data between the moving parts. Run the simulation: Once you have set up your simulation, you can run it using the Simulation module in STAR-CCM+. Make sure to monitor the convergence of the solution and adjust the settings as necessary. By following these steps, you can calculate a moving part coupled to another moving part in STAR-CCM+, including the DFBI main object moving in a wave, another object connected to it that can rotate, and another object rigidly connected to the Zhu object.
2023年4月18日
相似问题
查看全部
  • star ccm+和ansys的对比? 暂无回答
    star ccm+和ansys在流体和传热计算方面的对比各自有什么优势劣势?请有经验的人来讲讲呗~~~~~
  • ANSA和star-ccm仿真 暂无回答
    为什么我这里用ANSA做面网格(四边形),做好后以nas导入到star-ccm+里面,然后生成体网格,然后设置了一个发热模型,可是温度一点变化也没有,很奇怪,同样的操作直接导入part进去画体网格,相同的操作就可以,请问这是为什么??
  • 求一些STAR CCM+的资料? 2个回答
    求一些STAR CCM+的资料?
推荐阅读
RC1-传动系统基础概念设计
RC1-传动系统基础概念设计
林Rae 林Rae
免费
【精品课程】ANSA For LSDYNA从入门到精通(完结)
Wonderful仿真 Wonderful仿真
¥699
0#块箱梁托架法施工结构模拟
0#块箱梁托架法施工结构模拟
yudachuan1105 yudachuan1105
¥200
新一代智能头灯的动态设计评估与仿真
新一代智能头灯的动态设计评估与仿真
Ansys中国 Ansys中国
免费
UG培训第九课:自由曲面构造法
UG培训第九课:自由曲面构造法
luffy8610 luffy8610
¥20
应用ANSYS瞬态动力学法模拟啮合齿轮的高速转动
夏日星空 夏日星空
¥35
一线科技工作者接受仿真咨询服务的全过程经验分享
技术邻直播 技术邻直播
免费
UG有限元基础教程
UG有限元基础教程
moonshine🤓 moonshine🤓
免费
