顶部banner
Logo 折叠
全网首发仿真工程师项目实训
下载app
返回旧版
首页 成长助手 小邻学院 社区 发现
职业认证 企业服务 行业会议
登录解锁更多功能
还没有账号?立即注册
技术邻
技术引领职场价值
电话
0571-86682823
商务合作
service@jishulink.com
  • 全部  > 
  • CAE仿真
ABAQUST梁热力耦合翼变形缘板越薄越小,怎么修改?
浏览: 2407 回答: 3
abaqus建立T梁热力耦合模型,翼变形缘板越薄越小,怎么修改?
ABAQUS 热力耦合
全部回答 (2)
结构力学 2023年4月18日
To modify the thinner and smaller thermally coupled wing deflection edge plates of ABAQUS beams, you can follow these steps: Modify the geometry: You can modify the geometry of the wing plates to make them thicker and larger. This will increase their stiffness and reduce their deflection. You can do this by adjusting the dimensions of the plates in your CAD model or by using the Part module in ABAQUS to create a new plate geometry. Change the material properties: You can also change the material properties of the wing plates to make them stiffer. You can use a material with a higher modulus of elasticity or a higher yield strength. You can do this by defining a new material in ABAQUS or by modifying the existing material properties. Modify the mesh: You may need to modify the mesh to accommodate the new geometry of the wing plates. You can do this using the Mesh module in ABAQUS. You may also need to adjust the element size or type to ensure that the mesh accurately represents the geometry of the plates. Update the thermal coupling: If the wing plates are thermally coupled, you may need to update the thermal coupling parameters to reflect the new geometry and material properties of the plates. You can do this using the Step module in ABAQUS. Run simulations and analyze results: Once you have made the necessary modifications, you can run simulations to analyze the deflection behavior of the modified wing plates. You can use the Visualization module in ABAQUS to view the results of the simulation and determine if further modifications are needed. By following these steps, you can modify the thinner and smaller thermally coupled wing deflection edge plates of ABAQUS beams to improve their performance.
2023年4月18日
清水木木 2023年1月14日
楼主问题解决了吗?
2023年1月14日
已采纳 评论 1 点赞
相似问题
查看全部
  • 关于abaqus建模的问题,如何在模型中建立面? 关于abaqus建模的问题。 关于abaqus建模的问题。 关于abaqus建模的问题。 4个回答
    老师们好,这是我的模型,是用voronoi方法建立的,我现在想要使用cohesive接触,使用插件建立出来的模型想要去做cohesive 接触,其中到选择面这一步时出现问题,图中四边所围成的截面无法被选择(4条边可以选择,surface中无法选择此面),可以麻烦老师们抽空看一下我的这个问题应该如何解决么?类似圈出的面都无法选择,这是模型树。
  • 【abaqus-块石本构选取】abaqus模拟两块石接触,挤压破碎,abaqus有什么适合的模型? 2个回答
    各位大神好,我想用ABAQUS有限元模拟块石挤压,如角面接触时,接触部分的破碎压缩,破碎效果可能比较难以实现,所以想着是否以损伤近似模拟这些破碎量,如类似混凝土弹塑性损伤本构之类的,或者abaqus 里面有什么适合岩石的这种特性的模型~希望大家能指导下,越详细越好~~谢谢
  • abaqus 应力导入abaqus explict? 2个回答
    大神请问这个问题如何解决?
推荐阅读
ABAQUS钢管混凝土柱—钢梁节点抗震性能模拟
1点 1点
¥169
新四化浪潮下,传统汽车人如何积极转型
新四化浪潮下,传统汽车人如何积极转型
夸克 夸克
免费
abaqus_python提取odb中的最大值结果3
tanquery tanquery
免费
Cadence Fidelity 水泵水轮机CFD模拟解决方案和应用
Cadence楷登 Cadence楷登
免费
ANSYS新版本功能速递: HFSS微放电仿真
Ansys中国 Ansys中国
免费
Python面向对象的有限元编程
Python面向对象的有限元编程
weilai00 weilai00
¥60
基于ABAQUS和ANSYS接触分析
基于ABAQUS和ANSYS接触分析
宁博士CAE团队 宁博士CAE团队
免费
前沿技术!大数据分析及人工智能在优化软件中的应用
IDAJ中国 IDAJ中国
¥9.99
新一代智能头灯的动态设计评估与仿真
新一代智能头灯的动态设计评估与仿真
Ansys中国 Ansys中国
免费
5G终端天线仿真设计方法及其应用
5G终端天线仿真设计方法及其应用
Ansys中国 Ansys中国
免费
abaqus三维切削数值模拟(sph法)
abaquser abaquser
¥30
UG有限元基础教程
UG有限元基础教程
moonshine🤓 moonshine🤓
免费
ABAQUS钢管混凝土柱温度场及耐火性能分析(未完)
地下结构设计
¥40
一线科技工作者接受仿真咨询服务的全过程经验分享
技术邻直播 技术邻直播
免费
应用ANSYS瞬态动力学法模拟啮合齿轮的高速转动
夏日星空 夏日星空
¥35
混凝土材性试块拉压数值模拟(ABAQUS通法建模初级案例3)
大平-结构工程 大平-结构工程
¥299
UG培训第九课:自由曲面构造法
UG培训第九课:自由曲面构造法
luffy8610 luffy8610
¥20
汽车仪表模具模流分析的实战讲解
汽车仪表模具模流分析的实战讲解
北卡 北卡
免费
ABAQUS桁架结构强度分析
ABAQUS桁架结构强度分析
wj_2704 wj_2704
¥500
Altair基于仿真驱动的制造工艺解决方案
ALTAIR ALTAIR
免费
