有没有知道这个错误该怎么解决的? 100
浏览:1780 回答:1
  *** ERROR # 163 ***
  Too many vibration modes exist in the range of interest.
   Solver error no. =    725
         subcase id =      1
  This error happens as there are more than 500 eigenvalues calculated
  internally in the range of interest.
  The solver may require manual input to help targeting the frequency region
  of the desired modes. Please try the following two methods:
  1) Narrow the range of interest by adjusting the lower and upper bounds.
大龙猫🐱
软件是什么,版本是什么,怎么操作成这样的?最起码的问问题方式要知道
2023年1月30日
