顶部banner
Logo 折叠
全网首发仿真工程师项目实训
下载app
返回旧版
首页 成长助手 小邻学院 社区 发现
职业认证 企业服务 行业会议
登录解锁更多功能
还没有账号?立即注册
技术邻
技术引领职场价值
电话
0571-86682823
商务合作
service@jishulink.com
  • 全部  > 
  • CAE仿真
关于abaqus 优化模块中的由模态分析得到的Eigenfrequency怎么使用? 100
浏览: 2708 回答: 2
关于abaqus 优化模块中的由模态分析得到的Eigenfrequency怎么使用,在进行拓扑优化时候这个相关模块怎么使用
ABAQUS 模态分析 拓扑优化
全部回答 (2)
冰蓝i 2023年1月31日
有偿价格好商量
2023年1月31日
评论 点赞 1
结构力学 2023年4月18日
In Abaqus, you can use eigenfrequency data obtained from modal analysis to perform structural optimization. The eigenfrequencies of a structure represent the natural frequencies of vibration and can be used as a design parameter in optimization studies. Perform a modal analysis: Perform a modal analysis in Abaqus to obtain the eigenfrequencies and mode shapes of the structure. Define design variables: Define the design variables that you want to optimize. For example, you may want to optimize the thickness or shape of certain parts of the structure. Define objective function: Define the objective function that you want to optimize. In this case, you can use the eigenfrequency as the objective function. Define constraints: Define any constraints that you want to apply to the optimization, such as displacement or stress limits. Set up the optimization job: Set up the optimization job in Abaqus using the optimization module. Specify the design variables, objective function, and constraints. Run the optimization: Run the optimization job in Abaqus. The optimization algorithm will modify the design variables to try to achieve the target eigenfrequency while satisfying the constraints. Analyze the results: Analyze the optimization results to determine the optimal design variables that achieve the target eigenfrequency. It is important to note that when using eigenfrequency data for optimization, you must ensure that the structural modifications do not significantly alter the mode shapes or cause mode localization, which can lead to unexpected results. Therefore, it is recommended to use caution and verify the optimization results through further analysis and testing.|||||
2023年4月18日
相似问题
查看全部
  • 关于abaqus建模的问题,如何在模型中建立面? 关于abaqus建模的问题。 关于abaqus建模的问题。 关于abaqus建模的问题。 4个回答
    老师们好,这是我的模型,是用voronoi方法建立的,我现在想要使用cohesive接触,使用插件建立出来的模型想要去做cohesive 接触,其中到选择面这一步时出现问题,图中四边所围成的截面无法被选择(4条边可以选择,surface中无法选择此面),可以麻烦老师们抽空看一下我的这个问题应该如何解决么?类似圈出的面都无法选择,这是模型树。
  • 【abaqus-块石本构选取】abaqus模拟两块石接触,挤压破碎,abaqus有什么适合的模型? 2个回答
    各位大神好,我想用ABAQUS有限元模拟块石挤压,如角面接触时,接触部分的破碎压缩,破碎效果可能比较难以实现,所以想着是否以损伤近似模拟这些破碎量,如类似混凝土弹塑性损伤本构之类的,或者abaqus 里面有什么适合岩石的这种特性的模型~希望大家能指导下,越详细越好~~谢谢
  • abaqus 应力导入abaqus explict? 3个回答
    请问这个问题如何解决,大神,我这是把应力场导入动态分析的。
推荐阅读
转子旋转的周期性模型-水冷电机散热仿真
转子旋转的周期性模型-水冷电机散热仿真
技术邻小李 技术邻小李
¥100
ABAQUS热切割数值模拟
ABAQUS热切割数值模拟
hitliuyong hitliuyong
¥99
Altair SimSolid 求解精度控制和对标网络研讨会
ALTAIR ALTAIR
免费
Altair基于仿真驱动的制造工艺解决方案
ALTAIR ALTAIR
免费
HBK声学测量基础
HBK声学测量基础
HBK声学与振动 HBK声学与振动
免费
Mathcad基本操作
Mathcad基本操作
HYT HYT
¥89
后排座椅和安全带固定点强度分析
后排座椅和安全带固定点强度分析
Crisby_Vectory_TrHo Crisby_Vectory_TrHo
¥80
workbench纯六面体网格划分
workbench纯六面体网格划分
八号楼停水 八号楼停水
¥100
BOX-3D变宽斜钢箱梁绘图及功能更新演示
敦樸DUNPU 敦樸DUNPU
免费
新四化浪潮下,传统汽车人如何积极转型
新四化浪潮下,传统汽车人如何积极转型
夸克 夸克
免费
Cadence Fidelity 水泵水轮机CFD模拟解决方案和应用
Cadence楷登 Cadence楷登
免费
abaqus_python提取odb中的最大值结果3
tanquery tanquery
免费
十一特惠--Adams Car 模型建立的相关硬点及运动副
仿真分析 仿真分析
¥9.9
ANSYS新版本功能速递: HFSS微放电仿真
Ansys中国 Ansys中国
免费
0#块箱梁托架法施工结构模拟
0#块箱梁托架法施工结构模拟
yudachuan1105 yudachuan1105
¥200
基于Hypermesh与ABAQUS联合仿真的摄像头模组跌落分析——工作创建以及检查
北鲲 北鲲
¥99
ABAQUS钢管混凝土柱温度场及耐火性能分析(未完)
地下结构设计
¥40
5G终端天线仿真设计方法及其应用
5G终端天线仿真设计方法及其应用
Ansys中国 Ansys中国
免费
abaqus三维切削数值模拟(sph法)
abaquser abaquser
¥30
Python面向对象的有限元编程
Python面向对象的有限元编程
weilai00 weilai00
¥60
