Hypermesh+Abaqus接触问题?
浏览:1931 回答:1
Surface assembly__pickedsurf15 has facets that are not oriented properly with respect to each other. Check the element connectivities for underlying elements 4041 instance part-1-1 and 1548398 instance part-1-1 (sharing the common edge whose end points are nodes 141 instance part-1-1 and 142 instance part-1-1), as well as the *surface data cards to ensure that the surface normals are consistent. This message will not be repeated for other facets on this surface with similar problem.
Surface assembly__pickedsurf15 has facets that are not oriented properly with respect to neigh boring facets. Use available post processor to visualize surface normals.
Analysis Input File Processor exited with an error - Please see the  Job-2.dat file for possible error messages if the file exists..
这是为什么呢
李翔
看字面意思,应该是做接触的面没有找到相应的方向法线,你得查看单元,看看做出来的法线方向对不对
2023年4月21日
