ABAQUS接触问题?
浏览:2013 回答:1
Contact field output is requested for a node-based surface
           (*SURFACE, TYPE=NODE) spanning multiple instances in an
           Abaqus/Explicit analysis. This is currently not supported. Please
           remove the contact field output for the contact pair in question, or
           split the node-based surface into separate surfaces each spanning
           just one instance.
Wonderful仿真
接触输出的问题,不是接触问题
2023年3月21日
