顶部banner
Logo 折叠
全网首发仿真工程师项目实训
下载app
返回旧版
首页 成长助手 小邻学院 社区 发现
职业认证 企业服务 行业会议
登录解锁更多功能
还没有账号?立即注册
技术邻
技术引领职场价值
电话
0571-86682823
商务合作
service@jishulink.com
  • 全部  > 
  • CAE仿真
用inp文件定义局部坐标各向异性报错怎么解决? 110
浏览: 2936
我定义了一个8单元结构,在inp文件里想通过节点建立局部坐标系来赋予各向异性材料方向,但是导入之后会有“ValueError: operands could not be broadcast together with shapes (0,) (3,)  This occurred while creating part level orientation ORI-1. The region in question will not be imported. ”的提示报错,提示我创建局部坐标系出错,下面是我的inp文件:
*Heading
** Job name: Job-1 Model name: Model-1
** Generated by: Abaqus/CAE 2020
*Preprint, echo=NO, model=NO, history=NO, contact=NO
** PARTS
*Part, name=Part-1
*Node
      1, -0.00999999978, -0.00999999978, 0.0199999996
      2, -0.00999999978,           0., 0.0199999996
      3, -0.00999999978, 0.00999999978, 0.0199999996
      4, -0.00999999978, -0.00999999978, 0.00999999978
      5, -0.00999999978,           0., 0.00999999978
      6, -0.00999999978, 0.00999999978, 0.00999999978
      7, -0.00999999978, -0.00999999978,           0.
      8, -0.00999999978,           0.,           0.
      9, -0.00999999978, 0.00999999978,           0.
     10,           0., -0.00999999978, 0.0199999996
     11,           0.,           0., 0.0199999996
     12,           0., 0.00999999978, 0.0199999996
     13,           0., -0.00999999978, 0.00999999978
     14,           0.,           0., 0.00999999978
     15,           0., 0.00999999978, 0.00999999978
     16,           0., -0.00999999978,           0.
     17,           0.,           0.,           0.
     18,           0., 0.00999999978,           0.
     19, 0.00999999978, -0.00999999978, 0.0199999996
     20, 0.00999999978,           0., 0.0199999996
     21, 0.00999999978, 0.00999999978, 0.0199999996
     22, 0.00999999978, -0.00999999978, 0.00999999978
     23, 0.00999999978,           0., 0.00999999978
     24, 0.00999999978, 0.00999999978, 0.00999999978
     25, 0.00999999978, -0.00999999978,           0.
     26, 0.00999999978,           0.,           0.
     27, 0.00999999978, 0.00999999978,           0.
*Element, type=C3D8R
1, 10, 11, 14, 13,  1,  2,  5,  4
2, 11, 12, 15, 14,  2,  3,  6,  5
3, 13, 14, 17, 16,  4,  5,  8,  7
4, 14, 15, 18, 17,  5,  6,  9,  8
5, 19, 20, 23, 22, 10, 11, 14, 13
6, 20, 21, 24, 23, 11, 12, 15, 14
7, 22, 23, 26, 25, 13, 14, 17, 16
8, 23, 24, 27, 26, 14, 15, 18, 17
*Nset, nset=Set-1, generate
  1,  27,   1
*Elset, elset=Set-1, generate
 1,  8,  1
*Orientation, name=Ori-1, system=Z RECTANGULAR
1,13,4
1,0
** Region: (Section-1:Picked), (Material Orientation:element-1)
*Elset, elset=_I1
1,
** Section: Section-1
*Solid Section, elset=_I1, orientation=Ori-1, material=Material-1
*Orientation, name=Ori-2, system=Z RECTANGULAR
2,14,5
1,0
** Region: (Section-1:Picked), (Material Orientation:element-2)
*Elset, elset=_I2
2,
*Solid Section, elset=_I2, orientation=Ori-2, material=Material-1
*Orientation, name=Ori-3, system=Z RECTANGULAR
4,16,7
1,0
*Elset, elset=_I3
3,
*Solid Section, elset=_I3, orientation=Ori-3, material=Material-1
*Orientation, name=Ori-4, system=Z RECTANGULAR
5,17,8
1,0
*Elset, elset=_I4
4,
*Solid Section, elset=_I4, orientation=Ori-4, material=Material-1
*Orientation, name=Ori-5, system=Z RECTANGULAR
10,22,13
1,0
*Elset, elset=_I5
5,
*Solid Section, elset=_I5, orientation=Ori-5, material=Material-1
*Orientation, name=Ori-6, system=Z RECTANGULAR
11,23,14
1,0
*Elset, elset=_I6
6,
*Solid Section, elset=_I6, orientation=Ori-6, material=Material-1
*Orientation, name=Ori-7, system=Z RECTANGULAR
13,25,16
1,0
*Elset, elset=_I7
7,
*Solid Section, elset=_I7, orientation=Ori-7, material=Material-1
*Orientation, name=Ori-8, system=Z RECTANGULAR
14,26,17
1,0
*Elset, elset=_I8
8,
*Solid Section, elset=_I8, orientation=Ori-8, material=Material-1
*End Part
** ASSEMBLY
*Assembly, name=Assembly
*Instance, name=Part-1-1, part=Part-1
*End Instance
*Nset, nset=Set-1, instance=Part-1-1
  1,  2,  3, 10, 11, 12, 19, 20, 21
*Elset, elset=Set-1, instance=Part-1-1
 1, 2, 5, 6
*Elset, elset=_Surf-1_S4, internal, instance=Part-1-1, generate
 2,  8,  2
*Surface, type=ELEMENT, name=Surf-1
_Surf-1_S4, S4
*End Assembly
** MATERIALS
*Material, name=Material-1
*Elastic, type=ORTHOTROPIC
 1.37485e+08, 7.94493e+07, 1.37485e+08, 4.44715e+07, 4.44715e+07, 6.29233e+08,       1e+08,       1e+08
     3.2e+07,
** STEP: Step-1
*Step, name=Step-1, nlgeom=NO
*Static
1., 1., 1e-05, 1.
** BOUNDARY CONDITIONS
** Name: BC-1 Type: 对称/反对称/完全固定
*Boundary
Set-1, ENCASTRE
** LOADS
** Name: Load-1   Type: Pressure
*Dsload
Surf-1, P, 200000.
** OUTPUT REQUESTS
*Restart, write, frequency=0
** FIELD OUTPUT: F-Output-1
*Output, field, variable=PRESELECT
** HISTORY OUTPUT: H-Output-1
*Output, history, variable=PRESELECT
*End Step
请问我的错误在哪里呢
CAE ABAQUS
全部回答 (0)
相似问题
查看全部
  • abaqusDSA设计敏感性分析修改inp Solver Input File Processor? 5个回答
    请教各位大佬,用dsa设计敏感度分析功能做悬臂梁敏感度分析,inp文件用记事本修改后提交,数据检查能过,但是然后立即出现solver input file processor exited with an error,修改了几次还是有问题。请教一下如何解决,谢谢! 悬臂梁inp文件如下百度网盘: 链接:https://pan.baidu.com/s/12kigjtldkkdfog9bpqbtgg
  • Abaqus 帮助文档例子没有设置重力加速度也可以进行跌落? 4个回答
    在Abaqus帮助文档里面,有一个 circuit board drop test 的例子,为什么里面没有设置重力加速度也可以进行跌落?只有初速度? 如果想继续分析它二次跌落,是不是 一定 要加重力加速度? circuit.inp *HEADING Circuit board drop test -- 1.0 meter drop SI units (kg, m, s, N) *SYSTEM 0.
  • inp文件中已经删除相应单元,显示未定义属性? 1个回答
    part-1只留下一个PD3D单元,其余都删了,为什么还会说没定义属性 error信息: 1 elements have missing property definitions. The elements have been identified in element set ErrElemMissingSection. inp文件: *Heading ** Job name: Job-2 Mo
推荐阅读
手把手教你ABAQUS耗能钢节点建模与分析
1点 1点
¥169
Cadence Fidelity 水泵水轮机CFD模拟解决方案和应用
Cadence楷登 Cadence楷登
免费
abaqus_python提取odb中的最大值结果3
tanquery tanquery
免费
ANSYS新版本功能速递: HFSS微放电仿真
Ansys中国 Ansys中国
免费
0#块箱梁托架法施工结构模拟
0#块箱梁托架法施工结构模拟
yudachuan1105 yudachuan1105
¥200
基于Hypermesh与ABAQUS联合仿真的摄像头模组跌落分析——工作创建以及检查
北鲲 北鲲
¥99
ABAQUS钢管混凝土柱温度场及耐火性能分析(未完)
地下结构设计
¥40
5G终端天线仿真设计方法及其应用
5G终端天线仿真设计方法及其应用
Ansys中国 Ansys中国
免费
abaqus三维切削数值模拟(sph法)
abaquser abaquser
¥30
基于ABAQUS和ANSYS接触分析
基于ABAQUS和ANSYS接触分析
宁博士CAE团队 宁博士CAE团队
免费
前沿技术!大数据分析及人工智能在优化软件中的应用
IDAJ中国 IDAJ中国
¥9.99
新一代智能头灯的动态设计评估与仿真
新一代智能头灯的动态设计评估与仿真
Ansys中国 Ansys中国
免费
UG培训第九课:自由曲面构造法
UG培训第九课:自由曲面构造法
luffy8610 luffy8610
¥20
应用ANSYS瞬态动力学法模拟啮合齿轮的高速转动
夏日星空 夏日星空
¥35
一线科技工作者接受仿真咨询服务的全过程经验分享
技术邻直播 技术邻直播
免费
I-04稳态流:后台阶《STAR CCM+官方案例视频教程》
云之树 云之树
免费
混凝土材性试块拉压数值模拟(ABAQUS通法建模初级案例3)
大平-结构工程 大平-结构工程
¥299
汽车仪表模具模流分析的实战讲解
汽车仪表模具模流分析的实战讲解
北卡 北卡
免费
UG有限元基础教程
UG有限元基础教程
moonshine🤓 moonshine🤓
免费
ABAQUS桁架结构强度分析
ABAQUS桁架结构强度分析
wj_2704 wj_2704
¥500
