顶部banner
Logo 折叠
全网首发仿真工程师项目实训
下载app
返回旧版
首页 成长助手 小邻学院 社区 发现
职业认证 企业服务 行业会议
登录解锁更多功能
还没有账号?立即注册
技术邻
技术引领职场价值
电话
0571-86682823
商务合作
service@jishulink.com
  • 全部  > 
  • CAE仿真
大佬帮忙看看问题出在哪里了,感谢?
浏览: 3359
For two-dimensional models, if a non-unity thickness is specified for two-dimensional solid elements and these elements are involved in an interaction such as contact, the same thickness should be specified for the out-of-plane thickness of the corresponding surface under *surface interaction.
The request for mises output will be replaced by a request for s output
Integration and section point output variables will not be output for deformable elements that are declared as rigid using the *rigid body option
3 nodes associated with rigid bodies have boundary conditions prescribed at nodes other than the reference node. These boundary conditions will be transferred to the associated rigid body reference node.The reference nodes and the dependent nodes have been identified in node set WarnNodeOverconBoundRB.
Nodes belonging to 1 RIGID BODIES have boundary conditions prescribed at nodes other than the reference node. These boundary conditions indicate the rigid bodies cannot rotate about certain axes. Zero rotational boundary conditions have been added to these reference nodes.The reference nodes have been identified in node set WarnNodeOverconBoundRBRot.
343 nodes have dof on which incorrect boundary conditions may have been specified. The nodes have been identified in node set WarnNodeBCIncorrectDof.
DEFORM UT DIC
全部回答 (0)
相似问题
查看全部
  • abaqus monitor的問題,需如何改善? 6个回答
    You have entered a zero or negative density value. Abaqus allows non-physical data; however, most applications expect a positive density value and greater than 1.00000e-36 . 4 nodes associated with ri
  • 【ABAQUS--设置连接器】梁两端设置连接器不收敛? 4个回答
    麻烦大家指导下~~~~ ABAQUS模拟杆件系统中,一个杆两段均设置非线性轴向连接器,一开始就不收敛算不过去。尝试过一端连接器,一段MPC-tie连接可以收敛,希望大神指导下~~ 错误警告: One or more thickness of the box section is greater than 0.1 of the cross section dimension. The torsion
  • 水下井口局部有限元分析模型报错及警告问题求解? 暂无回答
    用ABAQUS进行分析时,总是算了一下就出错,看了一下warning和Error主要是这些问题,求问怎么解决? 1.5624 nodes have dof on which incorrect boundary conditions may have been specified. The nodes have been identified in node set WarnNodeBCIncor
推荐阅读
转子旋转的周期性模型-水冷电机散热仿真
转子旋转的周期性模型-水冷电机散热仿真
技术邻小李 技术邻小李
¥100
ANSYS新版本功能速递: HFSS微放电仿真
Ansys中国 Ansys中国
免费
0#块箱梁托架法施工结构模拟
0#块箱梁托架法施工结构模拟
yudachuan1105 yudachuan1105
¥200
ABAQUS钢管混凝土柱温度场及耐火性能分析(未完)
地下结构设计
¥40
abaqus三维切削数值模拟(sph法)
abaquser abaquser
¥30
前沿技术!大数据分析及人工智能在优化软件中的应用
IDAJ中国 IDAJ中国
¥9.99
新一代智能头灯的动态设计评估与仿真
新一代智能头灯的动态设计评估与仿真
Ansys中国 Ansys中国
免费
UG培训第九课:自由曲面构造法
UG培训第九课:自由曲面构造法
luffy8610 luffy8610
¥20
应用ANSYS瞬态动力学法模拟啮合齿轮的高速转动
夏日星空 夏日星空
¥35
一线科技工作者接受仿真咨询服务的全过程经验分享
技术邻直播 技术邻直播
免费
混凝土材性试块拉压数值模拟(ABAQUS通法建模初级案例3)
大平-结构工程 大平-结构工程
¥299
汽车仪表模具模流分析的实战讲解
汽车仪表模具模流分析的实战讲解
北卡 北卡
免费
UG有限元基础教程
UG有限元基础教程
moonshine🤓 moonshine🤓
免费
ABAQUS桁架结构强度分析
ABAQUS桁架结构强度分析
wj_2704 wj_2704
¥500
ADAS功能软件基础介绍
ADAS功能软件基础介绍
Alex王 Alex王
免费
使用已标定的车辆动力学模型提升开发效率
使用已标定的车辆动力学模型提升开发效率
VI-grade中国 VI-grade中国
免费
abaqus lamb波传播分析
abaqus lamb波传播分析
abaquser abaquser
¥25
abaqus模拟桩(三维)全过程
abaqus模拟桩(三维)全过程
红日当空q3120210076 红日当空q3120210076
¥62
热力学理论入门基础(上)
热力学理论入门基础(上)
引垂思汀 引垂思汀
¥30
solidworks 2016基础操作入门到精通
新征程学院 新征程学院
免费
