ansys计算发生了错误,应该怎么修改? 50
浏览:1702
A large negative pivot value (-4.185690834E-07) has been encountered in the global assembled matrix at the UZ degree of freedom of node 674122. This may be caused by a bad temperature-dependent material property used in the model.
