跑anasys maxwell2D时出现如下报错怎么解决呀?
浏览:1740
Com Engine non-responsive since 16:24:22, May 21, 2023.    Can be due to CPU intensive processing or network problems.    If persisting for long, manually kill the com engine process and restart analysis. Retrying.....
