建立子模型后,提交job显示这个问题怎么解决呢?
浏览:2207 回答:2
The driven node 19 for part instance JOINT-ARRAY-2 does not belong to any element from the global model.  Check coordinates, submodel exterior tolerance or absolute exterior tolerance.
The driven node 20 for part instance JOINT-ARRAY-2 does not belong to any element from the global model.  Check coordinates, submodel exterior tolerance or absolute exterior tolerance.
The driven node 22 for part instance JOINT-ARRAY-2 does not belong to any element from the global model.  Check coordinates, submodel exterior tolerance or absolute exterior tolerance.
The driven node 23 for part instance JOINT-ARRAY-2 does not belong to any element from the global model.  Check coordinates, submodel exterior tolerance or absolute exterior tolerance.
The driven node 32 for part instance JOINT-ARRAY-2 does not belong to any element from the global model.  Check coordinates, submodel exterior tolerance or absolute exterior tolerance.
The driven node 33 for part instance JOINT-ARRAY-2 does not belong to any element from the global model.  Check coordinates, submodel exterior tolerance or absolute exterior tolerance.
The driven node 35 for part instance JOINT-ARRAY-2 does not belong to any element from the global model.  Check coordinates, submodel exterior tolerance or absolute exterior tolerance.
The driven node 36 for part instance JOINT-ARRAY-2 does not belong to any element from the global model.  Check coordinates, submodel exterior tolerance or absolute exterior tolerance.
dwg_2931
子模型节点超出原模型了,把容差设大一点
2023年7月14日
评论 点赞 1
书海
建的不对,子模型里面的边界节点 找不到对应的整机驱动节点
2023年7月11日
评论 点赞 1
