hyperworks遇到的问题,如何解决?
浏览:1658 回答:1
*** ERROR #  79 ***
  DTPG data does not create any DVGRID data.
  There are no free referenced GRIDs.
  There may be no elements associated with the PSHELL data.
  LOAD or BOTH may be specified and all grids may be loaded.
  BC, SPC, or BOTH may be specified and all grids may be SPCed.
Wonderful仿真
没有优化设计变量
2023年7月13日
