请教下abaqus计算问题?
浏览:1754 回答:2
256 nodes are used more than once as a slave node in *TIE keyword. These constraints are not removed either due to the presence of *CONSTRAINT CONTROLS,NO CHANGES keyword or because removing the constraints might affect the model. The nodes have been identified in node set ErrNodeOverconTieSlave.
