abaqus 怎么删除0体积单元? 10
浏览:1978 回答:1
报错The volume of 2 elements is zero, small, or negative. Check coordinates or node numbering, or modify the mesh seed. In the case of a tetrahedron this error may indicate that all nodes are located very nearly in a plane. The elements have been identified in element set ErrElemVolSmallNegZero.已经在ErrElemVolSmallNegZero看到了0体积单元,但不知道怎么删除它们以便成功提交jobabaqus 怎么删除0体积单元?的图1abaqus 怎么删除0体积单元?的图2
静默的无线电
可以检查网格,将有问题的保存到集合里
2023年8月14日
