Maxwell 3D激励源不正确,如何解决,请大神指教? 10
浏览:1773 回答:1
在进行运算的时候报错,提示如下:
[error] Source setup is incorrect. Please make sure the sum of currents in each full winding must be zero in the both stationary moving region, respectively. The full winding is the complete physical winding without being reduced by independent/dependent and symmetry boundary. (2:36:18 下午 8月 06, 2023)
[error] Simulation completed with execution error on server: Local Machine. (2:36:18 下午 8月 06, 2023)
源设置不正确。请确保在两个固定移动区域内,每个全绕组的电流之和必须分别为零。全绕组是指不受独立/依赖边界和对称边界限制的完整物理绕组
1、永磁体不能挨着,相邻永磁体留有一点空间;
2、电流面在两端要有入有出,或者电流面放在导体中间只需要入
