ABAQUS提交子程序之后报错,想请问如何解决? 100
浏览:2051 回答:5
土的本构模型,模拟土的三轴动试验可以运行,在桩土模型中施加位移也可以运行,但是桩土模型中施加循环荷载算到一半就不动了,log文件如下
<9982 out of 9999 licenses remain available>.
Begin Compiling Abaqus/Standard User Subroutines
2023/8/9 17:07:59
Intel(R) Visual Fortran Intel(R) 64 Compiler for applications running on Intel(R) 64, Version 19.1.1.216 Build 20200306
Copyright (C) 1985-2020 Intel Corporation.  All rights reserved.
End Compiling Abaqus/Standard User Subroutines
Begin Linking Abaqus/Standard User Subroutines
  正在创建库 standardU.lib 和对象 standardU.exp
libirc.lib(fast_mem_ops.obj) : warning LNK4210: 存在 .CRT 节;可能有未处理的静态初始值设定项或结束符
End Linking Abaqus/Standard User Subroutines
2023/8/9 17:08:02
Begin Analysis Input File Processor
2023/8/9 17:08:02
Run pre.exe
2023/8/9 17:08:14
End Analysis Input File Processor
Begin Abaqus/Standard Analysis
2023/8/9 17:08:14
Run standard.exe
Shut-down takes longer than expected. Terminating analysis executable.
*** ABAQUS/standard rank 0 received the ABoRT signal
*** ERROR CATEGORY:  ELEMENT LOOP
2023/8/9 17:17:49
Abaqus Error: Abaqus/Standard Analysis exited with an error - Please see the
message file for possible error messages if the file exists.
Begin SIM Wrap-up
2023/8/9 17:17:51
Run SMASimUtility.exe
2023/8/9 17:17:51
End SIM Wrap-up
Abaqus/Analysis exited with errors
SnowWave02
可能就是普通的无法收敛的问题,减小分析步试试
2023年8月26日
评论 1 点赞 1
Ae╯烟雨行
我也有这个问题,但是就只是验证下软件就出现,也没提交具体的计算
2023年11月7日
南风CAEer
看提示是网格问题
2023年8月16日
