求助,这是什么问题呀,几分钟就莫名中断? 20
Command line options: i=cut_hole_stem_full2_6221RHT.k
NCPU=24
Input file: cut_hole_stem_full2_6221RHT.k
The native file format : 32-bit small endian
Memory size from default : 100000000, 0
Memory option : AUTO selected
Memory size from default : 100000000, 100000000
Memory for the head node
Memory installed (MB) : 191730
Memory available (MB) : 182431
allocating memory to 100000000 d 672 Initial allocation
******** notice ******** notice ******** notice ********
* This is the LS-DYNA Finite Element code. *
* Neither LST nor the authors assume any responsibility for *
* the validity, accuracy, or applicability of any results *
* obtained from this system. Users must verify their own *
* results. *
* LST endeavors to make the LS-DYNA code as complete, *
* accurate and easy to use as possible. *
* Suggestions and comments are welcomed. Please report any *
* errors encountered in either the documentation or results *
* immediately to LST through your site focus. *
* Copyright (C) 1990-2021 *
* by Livermore Software Technology, LLC *
* All rights reserved *
LSTC Environment Variables:
LSTC_MEMORY=auto
LSTC_LICENSE=ansys
Beginning of keyword reader 08/21/23 19:15:34
expanding memory to 182533160 d 47161142
*** Warning 70025 (OTH+25) (processor # 0)
Memory is set 82533160 words short
increase the memory size to 182533160
expanding memory to 192672780 d 47161142
Memory is set 10139620 words short
increase the memory size to 192672780
expanding memory to 192702780 d 47161142
Memory is set 30000 words short
increase the memory size to 196672780
expanding memory to 192762780 d 47161142
expanding memory to 192783846 d 47161142
expanding memory to 192804478 d 47161142
expanding memory to 233356958 d 47161142
Memory is set 36684178 words short
increase the memory size to 233356958
expanding memory to 273909438 d 47161142
Memory is set 40552480 words short
increase the memory size to 273909438
expanding memory to 273931638 d 47161142
Memory is set 22200 words short
increase the memory size to 277909438
expanding memory to 274046638 d 47161142
********** echo of pfile data **********
*********** end of pfile data **********
expanding memory to 279301556 d 47161142
Memory is set 1392118 words short
increase the memory size to 281909438
expanding memory to 284540602 d 47161142
Memory is set 2631164 words short
increase the memory size to 285909438
expanding memory to 342170108 d 47161142
Memory is set 56260670 words short
increase the memory size to 342170108
expanding memory to 347409154 d 47161142
Memory is set 5239046 words short
increase the memory size to 347409154
expanding memory to 352648200 d 138395222
increase the memory size to 352648200
*** Warning 11199 (KEY+1199)
DCT should be -1 in *CONTROL_ALE
*** Warning 10989 (KEY+989)
AFAC not equal to -1 in *CONTROL_ALE invokes ALE smoothing
which is not supported for MPP versions. Please turn it off
if set up by accident.
*** Warning 10302 (KEY+302)
CHECKING MATERIAL INPUT Part ID= 2
The default hourglass properties of the following
ALE part are being modified to avoid unnecessary
application of hourglass forces.
Resetting coefficient qm=1.0e-6.
PART ID 2 with
MATERIAL ID 2 and
EOS ID 2
This is PART 2 in the order of input.
CHECKING MATERIAL INPUT Part ID= 3
PART ID 3 with
MATERIAL ID 3 and
EOS ID 3
This is PART 3 in the order of input.
CHECKING MATERIAL INPUT Part ID= 4
PART ID 4 with
MATERIAL ID 3 and
EOS ID 3
This is PART 4 in the order of input.
CHECKING MATERIAL INPUT Part ID= 5
PART ID 5 with
MATERIAL ID 3 and
EOS ID 3
This is PART 5 in the order of input.
CHECKING MATERIAL INPUT Part ID= 6
PART ID 6 with
MATERIAL ID 3 and
EOS ID 3
This is PART 6 in the order of input.
CHECKING MATERIAL INPUT Part ID= 7
PART ID 7 with
MATERIAL ID 3 and
EOS ID 3
This is PART 7 in the order of input.
CHECKING MATERIAL INPUT Part ID= 8
PART ID 8 with
MATERIAL ID 3 and
EOS ID 3
This is PART 8 in the order of input.
CHECKING MATERIAL INPUT Part ID= 9
PART ID 9 with
MATERIAL ID 4 and
EOS ID 0
This is PART 9 in the order of input.
expanding memory to 357716770 d 138395242
Memory is set 5068570 words short
increase the memory size to 357716770
expanding memory to 362785330 d 138395242
Memory is set 5068560 words short
increase the memory size to 362785330
Memory required to process keyword : 362785330
Additional dynamic memory required : 138395242
allocating memory to 362785330 d 47161162 end of keyword reader
MPP execution with 2 procs
LS-DYNA will perform a structural only analysis
Initial reading of file 08/21/23 19:16:04
LS-DYNA keyword deck by LS-PrePost
ls-dyna mpp.190 s date 10/29/2021
expanding memory to 5493 d 748 material, node and element data
expanding memory to 5599 d 750 mat add general damage 0
expanding memory to 5689 d 750 material added airbag porosity leakage
expanding memory to 5725 d 750 material properties
expanding memory to 5752 d 60995011 element data for composite material
expanding memory to 5767 d 238269123 gradient of damage data
expanding memory to 6005 d 238269126 user control for contact interfaces
contracting memory to 5994 d 238269126 thermal expansion 0
expanding memory to 6003 d 238269126 state of charge expansion 0
expanding memory to 6005 d 238269126 cross-sectional force definitions 0
expanding memory to 5245051 d 238269180 temp index array for node sorting
contracting memory to 6005 d 243508230 just because?
expanding memory to 5074565 d 253986394 arbitrary element numbering input
*** Warning 20037 (STR+37)
Input contains 8 ALE parts.
Please use the keyword below to avoid potential problem.
*CONTROL_MPP_DECOMPOSITION_DISTRIBUTE_ALE_ELEMENTS
contracting memory to 6006 d 290017031 process element material data
expanding memory to 8007 d 290017022 load curve data
contracting memory to 6013 d 290017022 user_define_loading_set
expanding memory to 6213 d 290017022 regularize time history data
contracting memory to 6017 d 290017022 *DEFINE_ELEMENT_DEATH
expanding memory to 6581 d 325539181 contact interfaces
expanding memory to 7581 d 773737792 contact segment data 1
expanding memory to 56273199 d 773737792 contact segment data 3
contracting memory to 6581 d 778976838 contact definition
expanding memory to 6662 d 778976839 rigid body
expanding memory to 6666 d 778977913 contact friction
expanding memory to 6801 d 778977913 joints
expanding memory to 611473 d 778978513 non-reflecting silent boundary 1
expanding memory to 16063224 d 778978513 non-reflecting silent boundary 3
contracting memory to 611573 d 778978513 rigid bodies for disp. termination
expanding memory to 611582 d 816888492 ale reference system
expanding memory to 611734 d 816888492 ALE fsi control block
expanding memory to 611743 d 827366584 ALE fsi node and seg list
expanding memory to 611745 d 3215083135 ALE fsi coupling forces
expanding memory to 611823 d 3215083135 ALE storage for coupling shape functions
expanding memory to 21568181 d 3209673603 void materials
expanding memory to 21568190 d 3214912649 mat add cohesive 0
expanding memory to 21568199 d 3214912649 flexible body 2
Performing Decomposition -- Phase 1 08/21/23 19:17:01
expanding memory to 66573244 d 81612045 decomp reverse connectivity
expanding memory to 91916044 d 81612045 element ownership
Decomposition region 1:
Everything
Region 1 is distributed to 2 processors
With no coordinate transformation
Normalized element costs assigned during decomposition:
Minumum: 9.999746E-01
Maximum: 1.000026E+00
Standard Deviation: 2.542677E-05
contracting memory to 76880851 d 86851093 constraint scratch
expanding memory to 76880852 d 92090139 shadow node processing
expanding memory to 82119901 d 86851093 share node processing
contracting memory to 41605456 d 81612047 nodal sharing list
Memory required for decomposition : 91916044
Additional dynamic memory required : 3290m
allocating memory to 100000000 d 35995004 Allocate memory top of decomps
expanding memory to 1000001 d 35995004 hex ownership chunk
expanding memory to 1500880 d 35995004 hex ownership chunk
expanding memory to 2000768 d 35995004 hex ownership chunk
expanding memory to 2500656 d 35995004 hex ownership chunk
expanding memory to 2999421 d 35995004 hex ownership chunk
contracting memory to 2567889 d 35995004 hex ownership chunk
contracting memory to 1000001 d 38529285 hex sort chunk
expanding memory to 1500880 d 38529285 hex sort chunk
expanding memory to 2000768 d 38529285 hex sort chunk
expanding memory to 2500656 d 38529285 hex sort chunk
expanding memory to 2999421 d 38529285 hex sort chunk
contracting memory to 2567889 d 38529285 hex sort chunk
contracting memory to 10 d 35995006 material sort chunk
expanding memory to 28 d 35995006 material uid
expanding memory to 31 d 46609298 nodal force sharing lists 1
Performing Decomposition -- Phase 2 08/21/23 19:17:04
expanding memory to 40 d 41506421 mat scratch
expanding memory to 41 d 45142966 tied nodes scratch
expanding memory to 42 d 45142966 tied node scratch
contracting memory to 40 d 45142966 nodal rigid body scratch
expanding memory to 75624 d 45142966 non-reflecting boundary scratch
contracting memory to 49 d 45142966 tied ale scratch
expanding memory to 2609329 d 45142966 ale solid coupling scratch
contracting memory to 14 d 3255086762 ALE message buffers
expanding memory to 18 d 3255086762 ALE message buffers 2
expanding memory to 2704643 d 3255086762 ALE share node
Performing Decomposition -- Phase 3 08/21/23 19:17:09
expanding memory to 2710135 d 3259257603 material, node and element data
expanding memory to 2710241 d 3259257605 mat add general damage 0
expanding memory to 2710331 d 3259257605 material added airbag porosity leakage
expanding memory to 2710367 d 3259257605 material properties
expanding memory to 2710394 d 3287238009 element data for composite material
expanding memory to 2710409 d 3379004710 gradient of damage data
expanding memory to 2744704 d 3417018927 user control for contact interfaces
contracting memory to 2744693 d 3417018927 thermal expansion 0
expanding memory to 2744702 d 3417018927 state of charge expansion 0
expanding memory to 2744704 d 3417018927 cross-sectional force definitions 0
expanding memory to 5381248 d 3417018981 temp index array for node sorting
contracting memory to 2744704 d 3417018981 just because?
expanding memory to 5278985 d 3422292096 arbitrary element numbering input
contracting memory to 2744705 d 3434963538 d3thdt storage
expanding memory to 2744706 d 3573321066 process element material data
expanding memory to 2746707 d 3573321057 load curve data
contracting memory to 2744713 d 3573321057 user_define_loading_set
expanding memory to 2744913 d 3573321057 regularize time history data
contracting memory to 2744717 d 3573321057 *DEFINE_ELEMENT_DEATH
expanding memory to 2744797 d 3573321058 MPP copy of tim vector
expanding memory to 2745361 d 3591082145 contact interfaces
expanding memory to 2746361 d 4147387540 contact segment data 1
expanding memory to 30930241 d 4147387540 contact segment data 3
contracting memory to 2745361 d 4200118420 contact definition
expanding memory to 2745442 d 4200118421 rigid body
expanding memory to 2745469 d 4200118421 rbe2 scratch
contracting memory to 2745446 d 4200118832 contact friction
expanding memory to 2745581 d 4200118841 joints
expanding memory to 3039757 d 4200119441 non-reflecting silent boundary 1
expanding memory to 3039857 d 4200119441 rigid bodies for disp. termination
expanding memory to 3039919 d 4200119441 save d3plot control data
expanding memory to 3039928 d 4219163968 ale reference system
expanding memory to 3040080 d 4219163968 ALE fsi control block
expanding memory to 3040089 d 4224437056 ALE fsi node and seg list
expanding memory to 3040091 d 5416646181 ALE fsi coupling forces
expanding memory to 3040169 d 5416646181 ALE storage for coupling shape functions
expanding memory to 13586519 d 5411373097 void materials
expanding memory to 13586528 d 5408770595 mat add cohesive 0
expanding memory to 13586537 d 5408770595 flexible body 2
expanding memory to 18859626 d 5408770595 weld node list 1
expanding memory to 18927704 d 5408770595 weld node list 2
contracting memory to 16223083 d 5408770595 global pointers for welds
contracting memory to 13586538 d 5408770595 global shared weld node list 1
expanding memory to 13620578 d 5408770595 global shared weld node list 2
expanding memory to 13620611 d 5596404347 mpp general scratch
S t o r a g e a l l o c a t i o n
Memory required to begin solution : 31M
Additional dynamically allocated memory: 5602M
Total: 5633M
100 smallest timesteps
element number part timestep
solid 1146615 6 7.3510E-02
solid 1146587 6 7.3510E-02
solid 1145527 6 7.3510E-02
solid 1145499 6 7.3510E-02
solid 1105627 6 7.3510E-02
solid 1105599 6 7.3510E-02
solid 1104539 6 7.3510E-02
solid 1104511 6 7.3510E-02
solid 1064639 6 7.3510E-02
solid 1064611 6 7.3510E-02
solid 1063551 6 7.3510E-02
solid 1063523 6 7.3510E-02
solid 1023651 6 7.3510E-02
solid 1023623 6 7.3510E-02
solid 1022563 6 7.3510E-02
solid 1022535 6 7.3510E-02
solid 982663 6 7.3510E-02
solid 982635 6 7.3510E-02
solid 981575 6 7.3510E-02
solid 981547 6 7.3510E-02
solid 941675 6 7.3510E-02
solid 941647 6 7.3510E-02
solid 940587 6 7.3510E-02
solid 940559 6 7.3510E-02
solid 900687 6 7.3510E-02
solid 900659 6 7.3510E-02
solid 899599 6 7.3510E-02
solid 899571 6 7.3510E-02
solid 859699 6 7.3510E-02
solid 859671 6 7.3510E-02
solid 858611 6 7.3510E-02
solid 858583 6 7.3510E-02
solid 818711 6 7.3510E-02
solid 818683 6 7.3510E-02
solid 817623 6 7.3510E-02
solid 817595 6 7.3510E-02
solid 777723 6 7.3510E-02
solid 777695 6 7.3510E-02
solid 776635 6 7.3510E-02
solid 776607 6 7.3510E-02
solid 736735 6 7.3510E-02
solid 736707 6 7.3510E-02
solid 735647 6 7.3510E-02
solid 735619 6 7.3510E-02
solid 695747 6 7.3510E-02
solid 695719 6 7.3510E-02
solid 694659 6 7.3510E-02
solid 694631 6 7.3510E-02
solid 654759 6 7.3510E-02
solid 654731 6 7.3510E-02
solid 653671 6 7.3510E-02
solid 653643 6 7.3510E-02
solid 613771 6 7.3510E-02
solid 613743 6 7.3510E-02
solid 612683 6 7.3510E-02
solid 612655 6 7.3510E-02
solid 572783 6 7.3510E-02
solid 572755 6 7.3510E-02
solid 571695 6 7.3510E-02
solid 571667 6 7.3510E-02
solid 531795 6 7.3510E-02
solid 531767 6 7.3510E-02
solid 530707 6 7.3510E-02
solid 530679 6 7.3510E-02
solid 490807 6 7.3510E-02
solid 490779 6 7.3510E-02
solid 489719 6 7.3510E-02
solid 489691 6 7.3510E-02
solid 449819 6 7.3510E-02
solid 449791 6 7.3510E-02
solid 448731 6 7.3510E-02
solid 448703 6 7.3510E-02
solid 408831 6 7.3510E-02
solid 408803 6 7.3510E-02
solid 407743 6 7.3510E-02
solid 407715 6 7.3510E-02
solid 367843 6 7.3510E-02
solid 367815 6 7.3510E-02
solid 366755 6 7.3510E-02
solid 366727 6 7.3510E-02
solid 326855 6 7.3510E-02
solid 326827 6 7.3510E-02
solid 325767 6 7.3510E-02
solid 325739 6 7.3510E-02
solid 285867 6 7.3510E-02
solid 285839 6 7.3510E-02
solid 284779 6 7.3510E-02
solid 284751 6 7.3510E-02
solid 244879 6 7.3510E-02
solid 244851 6 7.3510E-02
solid 243791 6 7.3510E-02
solid 243763 6 7.3510E-02
solid 203891 6 7.3510E-02
solid 203863 6 7.3510E-02
solid 202803 6 7.3510E-02
solid 202775 6 7.3510E-02
solid 162903 6 7.3510E-02
solid 162875 6 7.3510E-02
solid 161815 6 7.3510E-02
solid 161787 6 7.3510E-02
1 t 0.0000E+00 dt 7.35E-02 flush i/o buffers 08/21/23 19:17:34
1 t 0.0000E+00 dt 7.35E-02 write d3plot file 08/21/23 19:17:34
*** Note history variables in lsprepost --> Fcomp -->misc
history variable 1 to 3 belongs to AMMG 1
history variable 4 to 14 belongs to AMMG 2
history variable 15 to 25 belongs to AMMG 3
history variable 26 to 36 belongs to AMMG 4
history variable 37 to 47 belongs to AMMG 5
history variable 48 to 58 belongs to AMMG 6
history variable 59 to 69 belongs to AMMG 7
history variable 70 to 76 belongs to AMMG 8
message里的内容到这里就没有了
有找到问题吗?我的和你的一样
