ABAQUS 错误求解答? 50
浏览:1464
Unable to delete file(s) C:\Users\123\AppData\Local\Temp\ABA_job-3_4546.
Please check that you have file ownership and permissions for removal.
进行data check 就会出现,手动删除后重新check会出现新的错误文件后缀,但是可以正常submit且运行。
