ANSYS中划分网格出错? 50
浏览:2325 回答:1
用mesh画网格,运行出错,怎么解决呢
(DP 0) Summary of the simulation:
The computation failed.
* Expert tool diagnostics *
Out of convergence disk
The problem F.E.M. Task has not converged.
* Expert tool advice in order to optimize the simulation *
At least one bad element has been detected in the mesh. The worst has the following feature(s) Too small angle in element 35986, (x,y,z) = (5.8216e-05, 0.0014438, 0.005265).
This can lead to local inaccuracies and possibly convergence difficulties. It is strongly recommended to fix the mesh.
狸叔VAONE
