abaqus报错?
浏览:1774
各位大佬知道abaqus把坐标换成柱坐标系出现以下警告应该怎么解决?
Transformation of coordinates is defined for 73 nodes that have no translational or rotational degrees-of-freedom.  The coordinate transformation will be ignored.  The nodes have been identified in node set WarnNodeNoMechanicalTransDef.
Abaqus IS UNABLE TO ESTIMATE AN AVERAGE INTERFACE ELEMENT LENGTH. THE WHOLE MODEL CHARACTERISTIC ELEMENT LENGTH IS USED INSTEAD.
