做SALE流固耦合时遇到下面报错,不想设置真空材料有神其他办法没?
浏览:1805
The # 2 ale multi-material which is of materialtype 10 has element erosion set. Please define anvacuum material and make it one of the ale multi-materialsso the failed material could be switched to vacuum.
