顶部banner
Logo 折叠
全网首发仿真工程师项目实训
下载app
返回旧版
首页 成长助手 小邻学院 社区 发现
职业认证 企业服务 行业会议
登录解锁更多功能
还没有账号?立即注册
技术邻
技术引领职场价值
电话
0571-86682823
商务合作
service@jishulink.com
  • 全部  > 
  • CAE仿真
ABAQUS计算过程报错,如何解决?
浏览: 4229 回答: 1
Job Job-2: Analysis Input File Processor completed successfully.
Error in job Job-2: Too many attempts made for this increment
Job Job-2: Abaqus/Standard aborted due to errors.
Error in job Job-2: Abaqus/Standard Analysis exited with an error - Please see the  message file for possible error messages if the file exists.
Job Job-2 aborted due to errors.
Output request damaget is not available for the material for element type c3d8
Output request damaget is not available for the material for element type s4
166117 elements are distorted. Either the isoparametric angles are out of the suggested limits or the triangular or tetrahedral quality measure is bad. The elements have been identified in element set WarnElemDistorted.
The aspect ratio for 130 elements exceeds 100 to 1. The elements have been identified in element set WarnElemAspectRatio.
1 elements are curved/warped. The angle subtended between the average element normal and a nodal normal exceeds 10 degrees. Mesh refinement is recommended. The elements have been identified in element set WarnElemWarped.
There are 116 unconnected regions in the model.
The plasticity/creep/connector friction algorithm did not converge at 800579 points
The plasticity/creep/connector friction algorithm did not converge at 1142412 points
The plasticity/creep/connector friction algorithm did not converge at 1238922 points
The plasticity/creep/connector friction algorithm did not converge at 1270393 points
The plasticity/creep/connector friction algorithm did not converge at 1278392 points
请教大佬如何解决
CAE ABAQUS
全部回答 (1)
TechmanLXS 2023年10月27日
不收敛,去你的msg看下详细信息。
2023年10月27日
相似问题
查看全部
  • abaqus桩土模拟地应力平衡? 2个回答
    请问一些,在进行桩土模拟时, A geostatic procedure with maximum displacement tolerances is supported only for the following materials: elastic, porous elastic, extended cam-clay plasticity model and mohr-coulomb pl
  • 关于abaqus计算不收敛的求助!! 暂无回答
    本人在模拟一个钢筋混凝土框架结构在竖向荷载及水平周期反复荷载作用时一直出现如下警告,然后计算一直不收敛。还望各位大神指点。模型在下方。 VF.zip Whenever a translation (rotation) dof at a node is constrained by a kinematic coupling definition the translation (rotation)
  • abaqus这是什么意思,最后算不过去,怎么解决? 6个回答
    The plasticity/creep/connector friction algorithm did not converge at 1 points The plasticity/creep/connector friction algorithm did not converge at 1 points The plasticity/creep/connector friction al
推荐阅读
手把手教你ABAQUS耗能钢节点建模与分析
1点 1点
¥169
汽车仪表模具模流分析的实战讲解
汽车仪表模具模流分析的实战讲解
北卡 北卡
免费
hypermesh_dyna小车碰撞护栏(无声)
吴文泽 吴文泽
¥18
使用已标定的车辆动力学模型提升开发效率
使用已标定的车辆动力学模型提升开发效率
VI-grade中国 VI-grade中国
免费
solidworks 2016基础操作入门到精通
新征程学院 新征程学院
免费
热力学理论入门基础(上)
热力学理论入门基础(上)
引垂思汀 引垂思汀
¥30
ABAQUS钢管混凝土柱温度场及耐火性能分析(未完)
地下结构设计
¥40
前沿技术!大数据分析及人工智能在优化软件中的应用
IDAJ中国 IDAJ中国
¥9.99
新一代智能头灯的动态设计评估与仿真
新一代智能头灯的动态设计评估与仿真
Ansys中国 Ansys中国
免费
abaqus三维切削数值模拟(sph法)
abaquser abaquser
¥30
UG有限元基础教程
UG有限元基础教程
moonshine🤓 moonshine🤓
免费
ANSYS新版本功能速递: HFSS微放电仿真
Ansys中国 Ansys中国
免费
基于Hypermesh与ABAQUS联合仿真的摄像头模组跌落分析——工作创建以及检查
北鲲 北鲲
¥99
0#块箱梁托架法施工结构模拟
0#块箱梁托架法施工结构模拟
yudachuan1105 yudachuan1105
¥200
一线科技工作者接受仿真咨询服务的全过程经验分享
技术邻直播 技术邻直播
免费
UG培训第九课:自由曲面构造法
UG培训第九课:自由曲面构造法
luffy8610 luffy8610
¥20
abaqus座椅滚轮拉脱力强度分析
abaqus座椅滚轮拉脱力强度分析
任总 任总
¥90
汽车模具工艺CAE分析
汽车模具工艺CAE分析
汽车-Albina 汽车-Albina
免费
十分钟快速进行电子产品结构设计方案评估
十分钟快速进行电子产品结构设计方案评估
技术邻直播 技术邻直播
免费
SolidWorks快速入门(操作+技巧+案例)试听课
宸格教育 宸格教育
免费
