For *tie pair (assembly_surf-tiedown-assembly_surf-tieup), adjusted nodes with very small adjustment
浏览:1653 回答:1
abaqus里For *tie pair (assembly_surf-tiedown-assembly_surf-tieup), adjusted nodes with very small adjustments were not printed. Specify *preprint,model=yes for complete printout.这句话意味着什么?
沈霆
构件间有小变形,帮你调整,告诉你一声
2023年12月30日
