想问一下各位大佬有没有人知道在workbench中施加螺栓预紧力进行求解,出现在下面的问题,可以解答一下吗?
浏览:1688 回答:1
The pretension load was not able to be applied. Make sure the load wasnot applied to a hole and that the load is not applied more than onceper surface or on different surfaces of the same body.
