- abaqus如何配置系统环境aba_sint_cap? 2个回答
Maximum size of static workspace has been exceeded. Current workspace size is 16384.00 mb. The size of the workspace can be increased using the system environment variable aba_sint_cap. 模型运行出现了以上问题,需要
- 请教ABAQUS提示SINT CAP IS REACHED,怎么解决? 4个回答
各位大神,请问ABAQUS计算时,提示 sint cap is reached: note that in this run sint was capped at 1550.21 MB. a higher sint cap can set using aba_sint_cap env variable. a following error massage will be issued and jo
- ansys model analysis 结果高于实验数据? 已解决
在做一个扇叶叶尖的modal analysis, 取了前5个mode的结果基本都是实验数据得出的两倍。模型的静力学预测和实验大部分都能对的上,就modal analysis这里差的很远。大家有没有什么想法?
