复合材料热冲压报错怎么办?
浏览:1753
***NOTE: THE MAXIMUM NUMBER OF TEMPERATURE VALUES PER NODE IN THIS ANALYSIS IS
17. THUS, 17 DATA FIELD(S) ON THE *INITIAL CONDITIONS,
TYPE=TEMPERATURE OPTION MUST BE SPECIFIED FOR EACH NODE OR NODE SET
***WARNING: THERE ARE TOO FEW DATA CARDS FOR THE INITIAL CONDITIONS OPTION.
ALL REMAINING VALUES ARE ASSUMED TO BE ZERO.
*initialconditions, type=TEMPERATURE
