abaqus报错
The strain at failure must be greater than zero
*density requires the use of *user material, *elastic, *eos, *hyperelastic, *anisotropic hyperelastic, *hyperfoam, *low density foam or *fabric
*drucker prager requires the use of *elastic or *porous elastic, type=logarithmic, or the combination of *eos and *eos shear, type=elastic options
53064 elements are missing elastic property reference. The elements have been identified in element set ErrElemMissingElasticPropRef.
Analysis Input File Processor exited with an error - Please see the Job-1.dat file for possible error messages if the file exists.
这是啥原因啊,我丢
全部回答 (1)
是不是用材料子程序了?
2024年4月19日
ABAQUS小土猪 2024年4月19日
