Ansysapdl建模,划分网格过后导入abaqus,图形不显示
浏览:1798
WARNING: Empty part PART-1. This occurred while reading keyword options within part definition.
WARNING: Part instance PART-1-1 references an empty part. A new part named PART-1-1 will be created from the mesh data in part instance PART-1-1.
WARNING: Empty part instance PART-1-1. This occurred while processing part PART-1. Neither the original part nor the part instance PART-1-1 contain mesh data.
会弹出这些警告,图形不显示,只有一个黄色的坐标系
