顶部banner
Logo 折叠
全网首发仿真工程师项目实训
下载app
返回旧版
首页 成长助手 小邻学院 社区 发现
职业认证 企业服务 行业会议
登录解锁更多功能
还没有账号?立即注册
技术邻
技术引领职场价值
电话
0571-86682823
商务合作
service@jishulink.com
dyna没有报错但是不能计算,什么原因?
浏览: 3138
 Input file: D:\ANSYS\bowen\0423\0423000.k
 The native file format       : 64-bit small endian
 Memory size from command line:    20000000
 allocating  memory to    20000000 d     1968951 Initial allocation
 ********  notice  ********  notice  ********  notice  ********
 * This is the LS-DYNA Finite Element code.                   *
 * Neither LST nor the authors assume any responsibility for  *
 * the validity, accuracy, or applicability of any results    *
 * obtained from this system. Users must verify their own     *
 * results.                                                   *
 * LST endeavors to make the LS-DYNA code as complete,        *
 * accurate and easy to use as possible.                      *
 * Suggestions and comments are welcomed.  Please report any  *
 * errors encountered in either the documentation or results  *
 * immediately to LST through your site focus.                *
 * Copyright (C) 1990-2021                                    *
 * by Livermore Software Technology, LLC                      *
 * All rights reserved                                        *
 Beginning of keyword reader                                   04/23/24 16:19:17
 expanding   memory to      138440 d     2008618
 expanding   memory to      168440 d     2008618
 expanding   memory to      189975 d     2068618
 expanding   memory to      214477 d     2109258
 expanding   memory to      236513 d     2109258
 expanding   memory to      291513 d     2109258
 expanding   memory to      313142 d     2285120
 expanding   memory to      334643 d     2588042
 Memory required to process keyword     :     334643
 Additional dynamic memory required     :    2591799
 contracting memory to           1 d     1981148 end of keyword reader
 LS-DYNA will perform a structural only analysis
 LS-DYNA keyword deck by LS-PrePost
                    ls-dyna smp d R13.0_365_f8a97bda2a  date 08/10/2021
 expanding   memory to        2001 d     1767258 material, node and element data
 expanding   memory to        2073 d     1767293 material properties
 expanding   memory to        2131 d     1990815 gradient of damage data
 expanding   memory to        2153 d     2047990 user control for contact interfaces
 contracting memory to        2133 d     2047992 thermal expansion 0
 expanding   memory to        2135 d     2047994 cross-sectional force definitions 0
 expanding   memory to        7715 d     2048008 temp index array for node sorting
 contracting memory to        2135 d     2053592 just because?
 expanding   memory to        6215 d     2064770 arbitrary element numbering input
 contracting memory to        2155 d     2102494 spc cards
 expanding   memory to        4155 d     2119973 load curve data
 expanding   memory to       16151 d     2119973 user_define_loading_set
 expanding   memory to       17553 d     2119973 regularize time history data
 contracting memory to       16155 d     2119973 *DEFINE_ELEMENT_DEATH
 expanding   memory to       28315 d     2159748 implicit contact 1
 contracting memory to       17155 d     2160069 contact segment data 1
 expanding   memory to       66535 d     2160069 contact segment data 3
 contracting memory to       16155 d     2305444 contact definition
 expanding   memory to       16159 d     2353602 contact friction
 expanding   memory to       16259 d     2354232 rigid bodies for disp. termination
     femsterNumDofs2    13594        1        0        1    13594
 femsterNumDofs2Glob    13594        1        0        1    13594
 expanding   memory to       16318 d     4457232 save d3plot control data
 expanding   memory to       16324 d     4479605 sensor_control for curve
 *** Warning 30210 (INI+210)
     Stress vs. plastic strain load curve ID = 1
     of part ID = 2 has a max. slope = 1.0730E+11
     which exceeds the Youngs modulus = 6.8900E+10
 S t o r a g e   a l l o c a t i o n
 Memory required to begin solution      :     335K
 Linear Alg dynamically allocated memory:     203K
 Additional dynamically allocated memory:    4517K
                                   Total:    5054K
 E r r o r   t e r m i n a t i o n                             04/23/24 16:19:17
 Memory required to complete solution   :     335K
 Linear Alg dynamically allocated memory:     636K
 Additional dynamically allocated memory:    4551K
                                   Total:    5522K
spooles objects usage
unfreed spooles objects
 T i m i n g   i n f o r m a t i o n
                        CPU(seconds)   %CPU  Clock(seconds) %Clock
  Keyword Processing ... 0.0000E+00    0.00     8.2000E-02    3.18
    KW Reading ......... 0.0000E+00    0.00     2.9000E-02    1.13
    KW Writing ......... 0.0000E+00    0.00     8.0000E-03    0.31
  Initialization ....... 2.0000E+00  100.00     2.4740E+00   96.04
    Init Proc Phase 1 .. 0.0000E+00    0.00     1.2800E-01    4.97
    Init Proc Phase 2 .. 0.0000E+00    0.00     3.0000E-03    0.12
  Init solver .......... 0.0000E+00    0.00     1.0000E-03    0.04
  EM solver ............ 0.0000E+00    0.00     1.9000E-02    0.74
    Misc ............... 0.0000E+00    0.00     1.9000E-02    0.74
  T o t a l s            2.0000E+00  100.00     2.5760E+00  100.00
 Problem time       =    0.0000E+00
 Problem cycle      =         0
 Total CPU time     =         2 seconds (   0 hours  0 minutes  2 seconds)
 CPU time per zone cycle  =          0.000 picoseconds
 Clock time per zone cycle=    4901960.789 picoseconds
 Number of CPU's    4
 NLQ used/max     136/  136
 Start time   04/23/2024 16:19:17
 End time     04/23/2024 16:19:17
 Elapsed time       0 second  for       0 cycles using  4 SMP threads
             (      0 hour   0 minute   0 second )
message文件没有报错,但就是跑不出来,大佬们该怎么处理?
Dyna
全部回答 (0)
相似问题
查看全部
  • ls-dyna 求解出错要怎么解决? 2个回答
    Executing with ANSYS license Input file: g:\xiansh~1\01\01_files\dp0\sys\mech\lsdyna~1.k The native file format : 32-bit small endian Memory size from default : 20000000 on UNIX computers note the fol
  • s-ale模拟爆炸计算无法进行? 1个回答
    模拟辛春亮老师第二版书中7.1例子,用sale方法模拟炸药炸钢板,用ls-run计算。几个小时进度一直在0%。 这是lsrun.out文件 License option : check ansys licenses only *************************************************************** * ANSYS 2022 R2 LEGAL N
  • LS-DYNA做爆破数值模拟,运行k文件后1分钟左右无故终止? 4个回答
    Date: 08/20/2023 Time: 21:43:43 ___________________________________________________ | | | Livermore Software Technology, LLC | | | | 7374 Las Positas Road | | Livermore, CA 94551 | | Tel: (925) 449-25
推荐阅读
ABAQUS中级教程合集--搞定滞回曲线
1点 1点
¥299
0#块箱梁托架法施工结构模拟
0#块箱梁托架法施工结构模拟
yudachuan1105 yudachuan1105
¥200
ABAQUS钢管混凝土柱温度场及耐火性能分析(未完)
地下结构设计
¥40
前沿技术!大数据分析及人工智能在优化软件中的应用
IDAJ中国 IDAJ中国
¥9.99
新一代智能头灯的动态设计评估与仿真
新一代智能头灯的动态设计评估与仿真
Ansys中国 Ansys中国
免费
UG培训第九课:自由曲面构造法
UG培训第九课:自由曲面构造法
luffy8610 luffy8610
¥20
应用ANSYS瞬态动力学法模拟啮合齿轮的高速转动
夏日星空 夏日星空
¥35
一线科技工作者接受仿真咨询服务的全过程经验分享
技术邻直播 技术邻直播
免费
混凝土材性试块拉压数值模拟(ABAQUS通法建模初级案例3)
大平-结构工程 大平-结构工程
¥299
汽车仪表模具模流分析的实战讲解
汽车仪表模具模流分析的实战讲解
北卡 北卡
免费
UG有限元基础教程
UG有限元基础教程
moonshine🤓 moonshine🤓
免费
ABAQUS桁架结构强度分析
ABAQUS桁架结构强度分析
wj_2704 wj_2704
¥500
ADAS功能软件基础介绍
ADAS功能软件基础介绍
Alex王 Alex王
免费
abaqus lamb波传播分析
abaqus lamb波传播分析
abaquser abaquser
¥25
abaqus模拟桩(三维)全过程
abaqus模拟桩(三维)全过程
红日当空q3120210076 红日当空q3120210076
¥62
TurboTides TurboTides
免费
场景仿真加速智能网联开发测试进程
场景仿真加速智能网联开发测试进程
海克斯康设计与仿真 海克斯康设计与仿真
免费
ANSYS speos汽车信号灯案例实操教程
IDAJ中国 IDAJ中国
¥9.9
ANSYS SI/PI/EMI&TI 2019 R3 新功能介绍
Ansys中国 Ansys中国
免费
复杂电驱动系统动态实时功率测试
复杂电驱动系统动态实时功率测试
HBK测试与测量 HBK测试与测量
免费
