蠕变子程序CREEP能调用最大主应力吗
浏览:1823 回答:1
我想计算用creep计算多轴蠕变应变
欢乐马仔
刚查了下creep可以调用USDFLD:
  • can be used in conjunction with user subroutine USDFLD to redefine any field variables before they are passed in.
通过定义STATEV:
This array will be passed in containing the values of these variables at the start of the increment unless they are updated in user subroutine USDFLD or UEXPAN, in which case the updated values are passed in.
所以,理论上来讲,你可以先在USDFLD里面获得最大主应力(GETVARM),然后再传到STATEV里面,最后在CREEP里面调用STATEV.
2024年5月27日
