ansys workbench23.1启动后,model模块无法打开问题
浏览:2043
系统版本:centos7.9
ansys workbench23.1
打开model后,查看后端日志,报错如下:
{5/31/2024 4:35:21 PM} [Ansys.Core.Commands.CommandFailedException:Message] Unable to start the Mechanical editor.
Ansys.Core.Commands.UserReadableFailureException: Unable to start the Mechanical editor.
  at Ansys.Addins.Infrastructure.CommandUtilities.CommandHelper.Execute (Ansys.Core.Commands.IFullContext context) [0x0004b] in <717a20c28b244621988b28ef1cecb819>:0
  at Ansys.Core.Commands.Concurrency.CommandWorkUnit.executeInContext (Ansys.Core.Commands.CommandContext subContext, Ansys.Core.Commands.Concurrency.IExecutionEngineCallback tracer) [0x000a1] in <7f5abd30a2404002a6021cbf74cfadfe>:0
  at Ansys.Core.Commands.Concurrency.BaseWorkUnit.doExecute (Ansys.Core.Commands.Concurrency.IExecutionEngineCallback executionEngine, Ansys.Core.Commands.CommandContext subContext) [0x0002d] in <7f5abd30a2404002a6021cbf74cfadfe>:0
  at Ansys.Core.Commands.Concurrency.BaseWorkUnit.Execute (Ansys.Core.Commands.Concurrency.IExecutionEngineCallback executionEngine, System.Boolean dontCatchExceptions) [0x0010f] in <7f5abd30a2404002a6021cbf74cfadfe>:0
--- Ansys.Core.Commands.CommandFailedException: Unable to start the Mechanical editor.
CommandName: Mechanical.EditModel(Container="Model")
  at Ansys.Core.Commands.CommandAsyncResult.RethrowFailureException (System.Exception e) [0x0000c] in <7f5abd30a2404002a6021cbf74cfadfe>:0
  at Ansys.Core.Commands.CommandAsyncResult.Wait (System.Int32 milliSecondsTimeout, System.Boolean exitContext) [0x00095] in <7f5abd30a2404002a6021cbf74cfadfe>:0
  at Ansys.Core.Commands.CommandAsyncResult.Wait () [0x00000] in <7f5abd30a2404002a6021cbf74cfadfe>:0
  at Ansys.Simulation.Core.Commands.EditModel.InvokeAndWait (Ansys.Core.Commands.IProtectedContext context, Ansys.Core.DataModel.ProjectSystem.DataContainerReference Container, System.Boolean Interactive, System.Boolean Hidden, System.Boolean StartAsReadOnly) [0x0003c] in <926f634c231749c3bd1ef0a831f9f7b7>:0
  at Ansys.Simulation.GUI.EditModel.InvokeCommand (Ansys.UI.GuiOperationContext context, Ansys.Core.DataModel.ProjectSystem.DataContainerReference dcr) [0x00006] in <ccf2d3ee547d4e1d9515463b49514b73>:0
  at Ansys.Simulation.GUI.EditModelBase.InvokeEditModelOperation (Ansys.UI.GuiOperationContext context, Ansys.UI.Interfaces.IGuiOperation guiOperation, Ansys.Core.DataModel.ProjectSystem.DataContainerReference dcr) [0x00284] in <ccf2d3ee547d4e1d9515463b49514b73>:0
  at Ansys.Simulation.GUI.EditModelBase.Invoke (Ansys.UI.GuiOperationContext context) [0x00012] in <ccf2d3ee547d4e1d9515463b49514b73>:0
  at Ansys.UI.GuiOperationContext.Invoke (Ansys.UI.GuiOperationMetaData operationData) [0x00006] in <9132acaa4ac1460fbf2777e5554a1cf7>:0
  at Ansys.UI.UIManager+<>c__DisplayClass206_0.<InvokeOperation>b__0 () [0x00031] in <9132acaa4ac1460fbf2777e5554a1cf7>:0
  at Ansys.UI.UIManager.InvokeOperationCore (System.String pseudoname, Ansys.UI.Views.View+OperationDelegate callback, System.Boolean allowOSMessages, System.Boolean coreTransaction, System.Boolean deferredRefreshOnly) [0x001a6] in <9132acaa4ac1460fbf2777e5554a1cf7>:0
请问哪位大神遇到过该问题,可以指导一下吗?
