abaqus显式设置报错in keyword *EQUATION, file "explicit1.inp", line 431601: Unknown assembly se
浏览:2002 回答:1
求助各位大佬,求求求大佬指点。我的这个模型一开始是隐式设置(digimat生成的),但是我看文献很多人使用的显式,我就在abaqus改了改相关操作,但是job提交就中断了,可是我的约束条件公式是digimat自己生成的,现在很无助,希望路过的大佬可以帮我
           assembly se的图1
ERROR: in keyword *EQUATION, file "explicit1.inp", line 431601: Unknown
           assembly set EQNSET-1
 ***NOTE: DUE TO AN INPUT ERROR THE ANALYSIS PRE-PROCESSOR HAS BEEN UNABLE TO
          INTERPRET SOME DATA.  SUBSEQUENT ERRORS MAY BE CAUSED BY THIS OMISSION
 ***ERROR: in keyword *EQUATION, file "explicit1.inp", line 431601: Unknown
           assembly set EQNSET-2
 ***ERROR: in keyword *EQUATION, file "explicit1.inp", line 431607: Unknown
           assembly set EQNSET-4
           assembly set EQNSET-5
 ***ERROR: in keyword *EQUATION, file "explicit1.inp", line 431613: Unknown
           assembly set EQNSET-7
           assembly set EQNSET-8
 ***ERROR: in keyword *EQUATION, file "explicit1.inp", line 431619: Unknown
           assembly set EQNSET-10
           assembly set EQNSET-11
 ***ERROR: in keyword *EQUATION, file "explicit1.inp", line 431637: Unknown
           assembly set EQNSET-19
William_7427
哥,解决了吗,我也遇到这个情况,求解答,谢谢您
2024年11月25日
