dflux子程序越界访问? 15
浏览:1932 回答:1
我是用abaqus子程序dlux施加在圆柱外表面热流密度表达式关于cos余弦函数,以下是子程序的代码,提示
ABAQUS/standard rank 0 encountered a SEGMENTATION FAULT
ERROR CATEGORY: ELEMENT LOOP是什么原因,应该怎么改
SUBROUTINE DFLUX(FLUX, SOL, KSTEP, KINC, TIME, NOEL, NPT, COORDS,
     1                 JLTYP, TEMP, FIELD, NFIELD, XSTATE, NSTATE,
     2                 PROP, NPROP, CELENT, DFGRD0, DFGRD1, NODFGRD,
     3                 CHARLEN)
C
      INCLUDE 'ABA_PARAM.INC'
C
C     Local parameters
      DIMENSION FLUX(NFIELD, NPT), TEMP(NPT), COORDS(NPT, 3),
     1 FIELD(NFIELD, NPT), XSTATE(NSTATE, NPT), PROP(NPROP)
C
C     Define constants and variables
      PARAMETER (PI = 3.141592653589793D0, DEGRAD = PI / 180.0D0)
      REAL*8 RADIUS
      DATA RADIUS /2.75D0/  ! Example radius, should be set appropriately
C
C     Calculate theta angle for each node on the cylinder surface
      DO I = 1, NPT
         RHO = SQRT(COORDS(I, 1)**2 + COORDS(I, 2)**2)  ! Distance from z-axis
         IF (ABS(RHO - RADIUS) .LT. 2.75D-6) THEN  ! Check if on cylinder surface
            THETA = ATAN2(COORDS(I, 2), COORDS(I, 1))  ! Calculate theta in radians
            IF (THETA .LT. 0.0D0) THEN
               THETA = THETA + 2.0D0 * PI  ! Normalize to [0, 2*pi]
            ENDIF
            FLUX(1, I) = 457.0D0 * COS(THETA)  ! Calculate flux
         ELSE
            ! Optionally handle nodes not on the cylinder surface
            FLUX(1, I) = 0.0D0  ! Or some other default value
         ENDIF
      END DO
C
      RETURN
      END
ymjyxw
粗略一看,2.75D应该是2.75*D,后面有好几处类似的错误
2024年8月26日
