LS-DYNA求解器,出现时间步问题?
各位大佬,LS-DYNA求解器的CESE模块,出现这个问题The LS-DYNA time step size should not exceed 1.026E-06 to avoid contact instabilities. If the step size is bigger then scale the penalty of the offending surface.也没报错就卡住不动了。
我的时间步设置为5e-7。造成这个问题的原因都有哪些?
CE/SE - State Variables
DOF ID Variable
1 Density
2 X-Momentum
3 Y-Momentum
4 Z-Momentum
5 Total Energy
& 0 Species Fractions
input of data is completed
initial kinetic energy = 0.00000000E+00
*** Warning 30131 (INI+131)
total number of massless nodes = 98
total nodal rigid body mass= 1.0928648E-04
The LS-DYNA time step size should not exceed 1.025E-06
全部回答 (1)
求,我也遇到一样的问题了
2024年10月17日
