ABAQUS梁柱现浇节点模拟,运行出现这个错误中断了,请教一下大神?
浏览:2206 回答:1
For two-dimensional models, if a non-unity thickness is specified for two-dimensional solidelements and these elements are involved in an interaction such as contact, the same thicknessshould be specified for the out-of-plane thickness of the corresponding surface under *surfaceinteraction.
1、可能的原因:模型维度与单元设置不匹配、接触相互作用定义错误
2、解放方案:检查和调整单元厚度设置(对于二维实体单元,尽量统一厚度的指定方式)、正确定义接触相互作用(重新定义表面,确保主从表面的定义方式一致)、审查接触属性的设置,确保其与二维实体单元的厚度指定不冲突
