顶部banner
Logo 折叠
全网首发仿真工程师项目实训
下载app
返回旧版
首页 成长助手 小邻学院 社区 发现
职业认证 企业服务 行业会议
登录解锁更多功能
还没有账号?立即注册
技术邻
技术引领职场价值
电话
0571-86682823
商务合作
service@jishulink.com
LSDYNA求解失败,出现下面问题,怎么解决?
浏览: 2884
Beginning of keyword reader                                   11/27/24 11:27:58
 *** Error 10246 (KEY+246)
     line contains improperly formatted data
      reading *DEFINE_CURVE card.
     There is an illegal TAB character at column 10
          At line# 653 of file
 D:\lunwen\11.27\11.24.k
         0      0
 *** Error 10450 (KEY+450)
     in keyword command:
20.20202        ,0.00514
          At line# 654 of file
 *** Warning 10435 (KEY+435)
     lines being skipped - See messag or d3hsp files
 *** Error 10133 (KEY+133)
     input data failed with: 3 errors
 E r r o r   t e r m i n a t i o n                             11/27/24 11:28:14
 Memory required to complete solution   :      13M
 Additional dynamically allocated memory:    7544K
                                   Total:      21M
 T i m i n g   i n f o r m a t i o n
                        CPU(seconds)   %CPU  Clock(seconds) %Clock
  Keyword Processing ... 1.6000E+01  100.00     1.6312E+01   99.78
    KW Reading ......... 1.0000E+01   62.50     9.5270E+00   58.28
    KW Writing ......... 1.0000E+00    6.25     7.1000E-01    4.34
  Initialization ....... 0.0000E+00    0.00     3.6000E-02    0.22
  T o t a l s            1.6000E+01  100.00     1.6348E+01  100.00
 Problem time       =    0.0000E+00
 Problem cycle      =         0
 Total CPU time     =        16 seconds (   0 hours  0 minutes 16 seconds)
 CPU time per zone cycle  =          0.000 picoseconds
 Clock time per zone cycle=          0.000 picoseconds
 Number of CPU's    0
 NLQ used/max     136/  136
 Start time   11/27/2024 11:27:58
 End time     11/27/2024 11:28:14
 Elapsed time      16 seconds for       0 cycles using  0 SMP thread
             (      0 hour   0 minute  16 seconds)
全部回答 (0)
相似问题
查看全部
  • s-ale模拟爆炸计算无法进行? 1个回答
    模拟辛春亮老师第二版书中7.1例子,用sale方法模拟炸药炸钢板,用ls-run计算。几个小时进度一直在0%。 这是lsrun.out文件 License option : check ansys licenses only *************************************************************** * ANSYS 2022 R2 LEGAL N
  • ls-dyna 求解出错要怎么解决? 2个回答
    Executing with ANSYS license Input file: g:\xiansh~1\01\01_files\dp0\sys\mech\lsdyna~1.k The native file format : 32-bit small endian Memory size from default : 20000000 on UNIX computers note the fol
  • dyna没有报错但是不能计算,什么原因? 暂无回答
    Input file: D:\ANSYS\bowen\0423\0423000.k The native file format : 64-bit small endian Memory size from command line: 20000000 allocating memory to 20000000 d 1968951 Initial allocation ******** notic
推荐阅读
手把手教你ABAQUS耗能钢节点建模与分析
1点 1点
¥169
Cadence Fidelity 水泵水轮机CFD模拟解决方案和应用
Cadence楷登 Cadence楷登
免费
abaqus_python提取odb中的最大值结果3
tanquery tanquery
免费
ANSYS新版本功能速递: HFSS微放电仿真
Ansys中国 Ansys中国
免费
0#块箱梁托架法施工结构模拟
0#块箱梁托架法施工结构模拟
yudachuan1105 yudachuan1105
¥200
基于Hypermesh与ABAQUS联合仿真的摄像头模组跌落分析——工作创建以及检查
北鲲 北鲲
¥99
ABAQUS钢管混凝土柱温度场及耐火性能分析(未完)
地下结构设计
¥40
5G终端天线仿真设计方法及其应用
5G终端天线仿真设计方法及其应用
Ansys中国 Ansys中国
免费
abaqus三维切削数值模拟(sph法)
abaquser abaquser
¥30
基于ABAQUS和ANSYS接触分析
基于ABAQUS和ANSYS接触分析
宁博士CAE团队 宁博士CAE团队
免费
前沿技术!大数据分析及人工智能在优化软件中的应用
IDAJ中国 IDAJ中国
¥9.99
新一代智能头灯的动态设计评估与仿真
新一代智能头灯的动态设计评估与仿真
Ansys中国 Ansys中国
免费
UG培训第九课:自由曲面构造法
UG培训第九课:自由曲面构造法
luffy8610 luffy8610
¥20
应用ANSYS瞬态动力学法模拟啮合齿轮的高速转动
夏日星空 夏日星空
¥35
一线科技工作者接受仿真咨询服务的全过程经验分享
技术邻直播 技术邻直播
免费
混凝土材性试块拉压数值模拟(ABAQUS通法建模初级案例3)
大平-结构工程 大平-结构工程
¥299
汽车仪表模具模流分析的实战讲解
汽车仪表模具模流分析的实战讲解
北卡 北卡
免费
UG有限元基础教程
UG有限元基础教程
moonshine🤓 moonshine🤓
免费
ABAQUS桁架结构强度分析
ABAQUS桁架结构强度分析
wj_2704 wj_2704
¥500
ADAS功能软件基础介绍
ADAS功能软件基础介绍
Alex王 Alex王
免费
