ABAQUS动力学计算导入初始应力后无法计算,该如何解决?
浏览:1127 回答:4
将静态压缩结果作为动力学计算初始状态,只导入变形后几何可以正常计算,导入应力场后计算5U报错,请大家帮忙看看怎么回事。
报错是:too many attempts made for this increment
警告信息:
Material/behavior pa has been redefined in the current analysis. Care must be taken to ensure that a consistent state can be maintained during the import procedure.
Whenever the reference node of *coupling + *kinematic is not attached to any imported element, its nodal results from the previous analysis are not imported. Consequently, the initial coupling surface configuration can be inconsistent with other parts of the model in the import analysis.
Excessive distortion at a total of 3630 integration points in solid (continuum) elements
