顶部banner
Logo 折叠
全网首发仿真工程师项目实训
下载app
返回旧版
首页 成长助手 小邻学院 社区 发现
职业认证 企业服务 行业会议
登录解锁更多功能
还没有账号?立即注册
技术邻
技术引领职场价值
电话
0571-86682823
商务合作
service@jishulink.com
  • 全部  > 
  • CAE仿真
abaqus动力显式模拟挤压,在运行一定过程,网格畸变过大,报错,想了解如何解决? 24
浏览: 4797 回答: 19 采纳: 1
报错信息为
The elements in element set ErrElemZeroALEMass-Step1 have zero or negative mass.
There are a total of 7 excessively distorted elements
The elements contained in element set ErrElemExcessDistortion-Step1 have distorted excessively.
以下是status文件相关信息
***WARNING: Master surface ASSEMBLY_SURF-CU-3 of contact pair # 5 contains
           facets with out-of-plane warping of at least 20.000 degrees in
           increment 22480. Large warping that develops during an analysis
           often corresponds to severe distortion of the underlying elements.
           It may be appropriate to rerun the analysis with a refined mesh.
   22776 5.442E-01 5.442E-01 00:39:14 2.400E-05       5853 7.245E+06 -3.111E+08 9.999E+05
INSTANCE WITH CRITICAL ELEMENT: P2CULAYER-1
***ERROR: Zero or negative mass in element number P2CULAYER-1.54179
***ERROR: Zero or negative mass in element number P2CULAYER-1.54186
***ERROR: Zero or negative mass in element number P2CULAYER-1.55131
***ERROR: Excessive distortion of element number 54186 of instance P2CULAYER-1
***ERROR: Excessive distortion of element number 55131 of instance P2CULAYER-1
***ERROR: Excessive distortion of element number 55369 of instance P2CULAYER-1
***ERROR: Excessive distortion of element number 55376 of instance P2CULAYER-1
***ERROR: Excessive distortion of element number 55377 of instance P2CULAYER-1
***ERROR: Excessive distortion of element number 55383 of instance P2CULAYER-1
***ERROR: Excessive distortion of element number 55384 of instance P2CULAYER-1
***WARNING: Mechanical penalty contact between surfaces ASSEMBLY_M_SURF-1 and
           ASSEMBLY_S_SURF-1 is causing a 72.434% reduction in the time
           increment.
***ERROR: There are a total of 7 excessively distorted elements
  The following checklist may be helpful in diagnosing the error:
   1. Check for poor initial mesh definition.
   2. Check the parameters used for ALE. Reducing the number of
      increments between ALE or increasing the number of sweeps in each ALE
      increment may yield a better mesh.
   3. Check contact definitions for problems such as excessive initial
      overclosure or unrealistic tied definition between contact pairs.
      A vector plot of velocities or accelerations will usually help to
      identify contact problems.
   4. Check stiffness (elastic modulus) and mass (density) definitions for
      consistent units and verify that the combination is reasonable.
   5. Check the boundary conditions for an excessive loading rate. The
      *DIAGNOSTICS, DEFORMATION SPEED=DETAIL option may be used to obtain
      detailed diagnostics information.
   6. Check the current status of the structure to see if it has
      totally failed.
   7. A dashpot or a very stiff spring may cause the analysis to go unstable.
      The *DYNAMIC, DIRECT option may be used to control the time increment
      directly.
***ERROR: The fatal error will generate a new field output in the last
         increment. All variables applicable to the current procedure and
         material type(s) will be written to the output database.
***ERROR: Excessive distortion of element number 47173 of instance P2CULAYER-1
***ERROR: Excessive distortion of element number 47179 of instance P2CULAYER-1
***ERROR: Excessive distortion of element number 47185 of instance P2CULAYER-1
***ERROR: Excessive distortion of element number 47186 of instance P2CULAYER-1
***ERROR: Excessive distortion of element number 47187 of instance P2CULAYER-1
***ERROR: Excessive distortion of element number 47939 of instance P2CULAYER-1
***ERROR: Excessive distortion of element number 47946 of instance P2CULAYER-1
***ERROR: Excessive distortion of element number 48163 of instance P2CULAYER-1
全部回答 (2)
不正经CAE工程师 2025年2月18日
报错的原因是网格畸变。如果是3D模型的话,建议使用欧拉法模拟,如果是2D模型,那么需要好好设计初始网格,或者使用ALE算法
2025年2月18日
已采纳 评论 16 点赞 1
momo_2899 2025年2月20日
建议使用ALE来解决
2025年2月20日
相似问题
查看全部
  • ABAQUS问题? 4个回答
    我用的是UMAT子程序,出现以下问题: The executable standard.exe aborted with system error code 1073740940. Please check the .dat, .msg, and .sta files for error messages if the files exist. If there are no error mess
  • 请教一下abaqus仿真这个问题怎么解决? 1个回答
    Error in job Job-1: The elements contained in element set ErrElemExcessDistortion-Step1 have distorted excessively. Error in job Job-1: Print-out suppressed for subsequent distorted elements Error in
  • abaqus显式分析增加网格密度后报错为什么? 2个回答
    ***ERROR: Bad Material definition in element number 1 instance SOIL-1: zero or negative initial dilatational modulus caused by bad material data. Please check your material input and any initial condi
推荐阅读
ABAQUS钢管混凝土柱—钢梁节点抗震性能模拟
1点 1点
¥169
ANSYS新版本功能速递: HFSS微放电仿真
Ansys中国 Ansys中国
免费
0#块箱梁托架法施工结构模拟
0#块箱梁托架法施工结构模拟
yudachuan1105 yudachuan1105
¥200
基于Hypermesh与ABAQUS联合仿真的摄像头模组跌落分析——工作创建以及检查
北鲲 北鲲
¥99
ABAQUS钢管混凝土柱温度场及耐火性能分析(未完)
地下结构设计
¥40
abaqus三维切削数值模拟(sph法)
abaquser abaquser
¥30
前沿技术!大数据分析及人工智能在优化软件中的应用
IDAJ中国 IDAJ中国
¥9.99
新一代智能头灯的动态设计评估与仿真
新一代智能头灯的动态设计评估与仿真
Ansys中国 Ansys中国
免费
UG培训第九课:自由曲面构造法
UG培训第九课:自由曲面构造法
luffy8610 luffy8610
¥20
应用ANSYS瞬态动力学法模拟啮合齿轮的高速转动
夏日星空 夏日星空
¥35
一线科技工作者接受仿真咨询服务的全过程经验分享
技术邻直播 技术邻直播
免费
混凝土材性试块拉压数值模拟(ABAQUS通法建模初级案例3)
大平-结构工程 大平-结构工程
¥299
汽车仪表模具模流分析的实战讲解
汽车仪表模具模流分析的实战讲解
北卡 北卡
免费
UG有限元基础教程
UG有限元基础教程
moonshine🤓 moonshine🤓
免费
ABAQUS桁架结构强度分析
ABAQUS桁架结构强度分析
wj_2704 wj_2704
¥500
ADAS功能软件基础介绍
ADAS功能软件基础介绍
Alex王 Alex王
免费
使用已标定的车辆动力学模型提升开发效率
使用已标定的车辆动力学模型提升开发效率
VI-grade中国 VI-grade中国
免费
hypermesh_dyna小车碰撞护栏(无声)
吴文泽 吴文泽
¥18
abaqus lamb波传播分析
abaqus lamb波传播分析
abaquser abaquser
¥25
abaqus模拟桩(三维)全过程
abaqus模拟桩(三维)全过程
红日当空q3120210076 红日当空q3120210076
¥62
