求助!lsdyna出现这个问题,并且一直卡住不往后计算了? 200
浏览:856 回答:3
*** Warning 30432 (INI+432)
SPH support normal mass scaling (dt2ms) features only
input of data is completed
initial kinetic energy = 0.00000000E+00
The LS-DYNA time step size should not exceed 1.512E+01
to avoid contact instabilities. If the step size is
bigger then scale the penalty of the offending surface.
到这之后就一直卡住也不往下进行了。
