请问这种情况该怎么解决?
浏览:522
The reference node of Analytical rigid surface ASSEMBLY_DOWNGROOVE_DOWNGROOVE is part of a constraint system that will be solved implicitly. The analysis cannot proceed because this node is shared between domains. To avoid this situation use discretized rigid surface in place of the analytical rigid surface.
