求助!lsdyna出现这个问题,一直卡住不往后计算了,请问该怎么解决?
浏览:1320 回答:1
Beginning of keyword reader 03/10/25 15:53:06
Memory required to process keyword : 31636524
*** Warning 21131 (STR+1131)
Space dimension for SPH set to 3D (IDIM changed from 0 to 3)
input of data is completed
initial kinetic energy = 0.00000000E+00
The LS-DYNA time step size should not exceed 1.546E+01
to avoid contact instabilities. If the step size is
bigger then scale the penalty of the offending surface.
Memory required to begin solution : 90M
Additional dynamically allocated memory: 119M
Total: 209M
initialization completed
Message 40538 (SOL+538) exceeds 50 times
Further printing will be suppressed from screen only
Summary of warning messages for interface # = 1
number of warning messages = 489432
1 t 0.0000E+00 dt 1.61E+00 flush i/o buffers 03/10/25 15:55:45
1 t 0.0000E+00 dt 1.61E+00 write d3plot file 03/10/25 15:55:45
到这里就不动了
