ABAQUS报错?
浏览:480
ABAQUS报错?的图1
钢筋混凝土梁冲击报错 9774 nodes on an embedded element do not lie in any host element. Check coordinates, exterior tolerance and absolute exterior tolerance parameters, and the host element set definition. The nodes have been identified in node set ErrNodeEmbeddedNode.怎样去解决?求助大佬
